07-23-2018, 07:34 PM | #4781 |
| Re: GT3B Hack Question and Answer Thread |
08-06-2018, 11:52 PM | #4782 |
Rock Crawler Join Date: May 2018 Location: USA
Are there any receivers that are capable of handling high voltage? Id like to run it at 8.4v.
09-16-2018, 03:16 PM | #4783 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
Anyone willing to explain how to set up a hacked gts-c to use the ax wire on the mambax. Thanks in advance. Quote:
09-16-2018, 03:30 PM | #4784 |
09-16-2018, 03:58 PM | #4785 |
| Re: GT3B Hack Question and Answer Thread First is this you? If it is this is the most useful video on he flysky I have seen because of the order and flash cards. I use this all the time even though I have 5 transmitters. Second, yeah I don't know wtf Im doing? Im good at a lot of this, but frankly I have no Idea how to set up the channel. I just dont understanding the ms settings, is this something I am doing in the flysky, in castle link, or not at all. Am I setting the channel with the Aux cable up like a shifting servo? IN the mean time Im going to go mess with thinks see if I can muddle through. |
09-16-2018, 04:01 PM | #4786 |
Duh, got it.. thank you |
09-16-2018, 04:11 PM | #4787 |
09-23-2018, 09:20 AM | #4788 |
Newbie Join Date: Sep 2018 Location: Charlottenberg
Where can I buy required hardware needed for hack besides the transmitter?
09-23-2018, 09:24 AM | #4789 |
Newbie Join Date: Jan 2018 Location: The Netherlands
09-23-2018, 11:05 AM | #4790 | |
| Re: GT3B Hack Question and Answer Thread Quote: | |
09-29-2018, 06:37 AM | #4791 |
Quarry Creeper Join Date: Oct 2017 Location: The Netherlands
I have 5 Flysky GT3Cs, all modded to 8ch. Love them, except for one small fault with all of them. The foam of the steering wheel. Too lose even with new ones and the steering wheel is wider as the foam. The foam always slip and slide on the wheel. But... I found a perfect and cheap replacement foam! If you have the same problem, here is the solution. Get yourself a new foam from Traxxas. Part number #2224. It is the foam for most of their transmitters. I tried the foam of my Traxxas TRX-4 transmitter on my Flysky GT3C. Perfect fit. The inner diameter of the Traxxas foam is just a bit smaller as the GT3C foam, but perfect for the GT3C wheel. You have to strech the Traxxas foam just a bit over the GT3C wheel and than no more slip. Bonus, it is just as wide as the GT3C steering wheel, so no more sliding from side to side of the foam over the wheel. And it is also thicker. That last part makes another mod possible. Because now you can use another mod that was only designed for the GT3B. Because the outer diameter is with this Traxxas foam the same as the outer diameter of the GT3B wheel, you can now 3D print yourself the (OHD) One Hand Drive for FLY Sky FS-GT3B Radio designed by Adam @ Spare Time Hobbies and available at Pinshape. https://pinshape.com/items/22466-3d-...-fs-gt3b-radio This OHD mod will not work on the GT3C with the original GT3C foam without changing the design, as in changing the inner diameter of the OHD. But it will work with the thicker Traxxas foam mod without changing anything to the 3D print design. So there you have it, a mod for a better foam and a way to use your GT3C (and offcourse GT3B) with only one hand. Last edited by Cesco; 09-29-2018 at 06:40 AM. |
10-13-2018, 09:09 AM | #4792 |
Rock Stacker Join Date: Dec 2005 Location: usa
hi guys i have been out for a while. can someone please help me. I'm trying to do the gt3b firmware upgrade. i have followed all the steps. i plug in and launch stvp.click open and try to load the updated file and it keeps saying FILE ; LINE 7 NOT IN MOTOROLA S19 FORMAT. please help before i smash everything. thanks guys ,i like what you've done with the place |
10-13-2018, 09:15 AM | #4793 | |
Rock Stacker Join Date: Dec 2012 Location: HESPERIA, SoCAL
The file I have is The known working file I have D/L from and continue to use is 62.0 KB from Index of /GT3B/GT3B-Firmware/0-6-1/ which loaded correctly on the STVP loader. I tried the file from github, and got the same Error : FILE : line 7: Not in Motorola S19 format! when I tried to load it. Here are the results from the STVP programming window. GITHUB FILE > Loading file C:\C:\*****\RC\FLYSKY HACK\gt3b-0.6.1.s19 in PROGRAM MEMORY area ... Error : FILE : line 7: Not in Motorola S19 format! Error : < File loading failed. OVERKILLRC FILE > Loading file C:\*****\RC\FLYSKY HACK\XXXgt3b-0.6.1.s19 in PROGRAM MEMORY area ... (Ignor the XXX, kept the files in same folder.) < File successfully loaded. File Checksum 0x26C9BC BTW, been running Windows 7 but I know it has been done on Win 10. Last edited by BAD RC; 10-13-2018 at 11:31 AM. | |
10-13-2018, 07:21 PM | #4794 |
thanks bad rc. the firmware seems to have worked . but now the radio won't power up any ideas? |
10-13-2018, 10:19 PM | #4795 |
10-14-2018, 06:52 PM | #4796 |
all good ,thanks very much.my old bruiser won't know what hit her |
10-14-2018, 07:18 PM | #4797 |
11-17-2018, 08:37 PM | #4798 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
11-17-2018, 09:22 PM | #4799 |
Newbie Join Date: Nov 2018 Location: Australia
Hello all, just wundering if anybody can help me, I have a FS-GT3C and want to set it to use on my scania r620 highline truck with a tamiya MFC-03. Does anybody here know the settings to use as I have no idea and it is getting annoying.
11-18-2018, 05:28 PM | #4800 | |
Nice job of explaining this. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
