![]() | #4841 | |
| ![]() Quote:
![]() | #4842 |
RCC Addict ![]() Join Date: Sep 2010 Location: Apollo Pa
No problem I'll help when I can.
![]() | #4843 |
Newbie Join Date: Feb 2019 Location: London
I'm not sure if this is the best forum for my question but you may be able to help me with my problem. I have an unhacked FS-GT3B that is malfunctioning and I am wondering if it can be repaired. Here is what it does: I removed the AA batteries and attached a regulated 12V supply to eliminate the possibility of low power. - when turned ON, it displays "MODEL 1 FS1" and no function at the top is lit up. So far so good. - when I press ENTER down, nothing changes - when I turn ENTER either way, nothing happens - when I press END, nothing happens - when I press BACK, "ERR" is displayed for about 1 second, then some numbers appear, like "867" or "794" - when I press CHANNEL-3, All data on the display lights up for about 1 second, such as "LOW POWER", CHANNEL" and "MODEL" all at the same time for about 1 second. - I can not get the functions to light up at the top of the screen at all. When fiddling around with the controls one time I was able to get it to show the voltage (11.9V) and the "NAME" function lit up. I proceeded to try changing the letters in the model name but it would only change the first letter. The next time I powered it up it had erased that letter and reverted to "FS1". I have never been able to get any functions to light up after that one time. After all this I decided it may be a bad connection, so I carefully opened the case, removed the display and re-seated all the plug-in connectors. After re-assembly there was no change at all. Is there any way this radio can be totally reset somehow? Any ideas? Thanks in advance for any help. Fred |
![]() | #4844 |
Newbie Join Date: Jul 2016 Location: An igloo
Hey, can I still get a kit for for my gt3c? Very interested, and paypal ready |
![]() | #4845 |
Quarry Creeper Join Date: Jan 2018 Location: Norway
![]() | #4846 |
| ![]() I love these radios, for the money can't be beat. Your welcome.
![]() | #4847 |
Newbie Join Date: Jan 2019 Location: Fernandina Beach, FL
I keep getting the message that the swim is not communicating. I've checked connections. Tried without and with batteries and power switch on and off. Not sure what I'm missing. Red light is on on st link till I get the error. And controller beeps until I try to read it. Any suggestions? I've read 4k posts and still nogo. Thanks so much. Sent from my SAMSUNG-SM-G930A using Tapatalk |
![]() | #4848 |
Newbie Join Date: May 2019 Location: Philippines
Hey Guys, Forgive if I am in the wrong thread. I am new to this hobby and I know I'm joined too late, I could tell by how far the very first post was created lol. So I just got my first pistol type radio which is a modded GT3C with 4 additional channels. They call it DASMIKRO customized GT3C which basically has a 4 channel PPM expander board inside. I want to be able to assign/reassign channels on those additional pots and switches. My question is, can I flash it with the latest PSX custom firmware version 0.6.1 with no issue? Thank you for yoir help. |
![]() | #4849 | ||
Quarry Creeper Join Date: Oct 2017 Location: The Netherlands
All depends on which DASMIKRO version you have of the Flysky GT3C. There are different versions. 1. DasMikro Customized 8CH Firmware PSX0.6.1 Flysky GT3C Transmitter https://www.banggood.com/DasMikro-Cu...r_warehouse=CN This is just the Flysky GT3C with the hacked software, it does not have the toggle and switch options. You program the buttons that are already on the transmitter. So it is a 8 channel radio through firmware update. 2. Dasmikro Customized 8 Channel Flysky GT3C Transmitter Toogle Switch 3 Position Adjustable https://www.banggood.com/Dasmikro-Cu...r_warehouse=CN Quote:
https://www.banggood.com/DasMikro-PS...r_warehouse=CN Quote:
https://www.aliexpress.com/item/Dasm...42939207EbNqCc This was a DIY kit to turn a stock Flysky GT3C 3 channel radio into a 8 channel. It involved soldering and making modifications to the GT3C to instal te switches. There was a A and B version if I am correct. With one version you kept the 3th channel button function and in the other version it is replaced by a switch. If you have option 1 or 3 it already has the PSX firmware upgrade. If you have option 2 or 4, it was not supposed to be updated with the PSX firmware, but designed for the Flysky 3 channel firmware. I might be wrong here, but that is as far as I am aware of. Not quite sure if you can turn option 2 into option 3 with the firmware upgrade. I have 5 GT3Cs and I did upgrade them all with the PSX firmware. There is also a a GT3 topic (several), more information on the Dasmikro will be in there. Last edited by Cesco; 05-16-2019 at 04:22 AM. | ||
![]() | #4850 | |
Mine is the same with #2. Stock GT3C firmware with additonal 4 toggle switches and pots using the PPM expander board. I wish I could flash it and make it the same as #3. I did search the net already but found limitted result about GT3C with DASMIKCRO version. This is the best thread/forum I found next is rctech.net. Quote:
![]() | #4851 | |
Physically, mine looks exactly the same as #3. On the banggod description it says "Key Mapping (Assign ANY key to operate ANY function)". This in way give me clue that has the same hardware hack as mine with normal PSX 0.6.1 firmware. If only I could find someone that owns one of #3 and could extract the firmware and upload it somewhere... Quote:
![]() | #4852 |
Hey Guys, Anybody has a GT3C custom firmware that would work with GT3C that has the 4 channel ppm extension board they could share? Thanks a lot! |
![]() | #4853 |
Newbie Join Date: May 2019 Location: Bruton
| ![]() Afaik, its the same 0.6.1 software. I hacked my gt3c, updated the reverse menu wheel and such, then saved that copy to pc. I assume that would work better for everyone with gt3c but don't know why its not been done before. I wish i could find someone with a comprehensive understanding of how the Dasmikro expander boards work and their variants. I need help with a project that would benefit the RC community greatly. Trust. Please get hold of me if you do. Sent from my S60 using Tapatalk |
![]() | #4854 |
The Dasmikro expander boards probably just inject the channels into the ppm stream going to the transmit module.....But i've never bought one to see. Firmware upgrade is a much better option in my opinion. Also, 0.6.1 firmware allows you to reverse the scroll wheel in the Global Menu Last edited by losikid; 07-12-2019 at 10:54 PM. |
![]() | #4855 |
Hey Guys, saw your responses just now and thought I should provide info of what I've done. So mine was a GT3C with the 4 channel expander board with stock firmware. The expander board inside the transmitter is basically tap to the PPM output pin of the transmitter board and separate the channels. So the Expander board is basically a PPM decoder. There's a resistor with refdes R13 with value of 5.1KOhms that was removed on the board and it's right on one of the 4pins where you connect the STLINK. I first though this was necessary or else the PPM decoder won't work but that was just my theory since I couldn't really find any info on this MOD anywhere online. But I believe this was done primarily to prevent the owner from flashing it with custom firmware due to the fact that dasmikro is also selling a version of this transmitter with both the expander board and custom firmware installed as well which I found out about when I already bought mine. So frustrated and really wanted to be able to use use the custom firmware with the fixes and other goodies, after finding out the value of the R13 resistor I went ahead and install the missing resistor and proceeded with the plan. I was able to back up the stock pre-installed firmware and flashed the custom firmware without any issue. The entire process went smoothly. Guess what!? the transmitter booted and work just fine. The 4 channel expander board still works while also having the benefits of the custom firmware. I now have a 7 Channels GT3C... default channels 1 and 2 then I reassigned channel 3 as trim for channel 2(forward) and channels 4,5,6 and 7 from the expander board that are pots and 3 way switches assigned to do other things. This way I don't have to mess with the default functions of the other buttons on the transmitter. Last edited by flatronics; 07-28-2019 at 10:42 AM. |
![]() | #4856 |
Newbie Join Date: Jul 2019 Location: Bristol, UK
Can somebody please answer a couple of questions? I just want to make sure I got things straight in my head. I've found the below Transmitter on Aliexpress https://www.aliexpress.com/item/32840643597.html So this would be the GT3C with the custom firmware that allow up to 8 channel control using the stock buttons without any additional switches or pots? I want it to work like the one in this video. https://www.youtube.com/watch?v=SpIoLgmI1xw Lastly, what is the best receiver to get to use with the GT3C 8 Channel? Thanks. |
![]() | #4857 | |
Yes, the one you link has the custom firmware preinstalled and without ports and switches installed. I am not sure though if it has the other 5 channels pre set-up already. Not sure of the best 8 channel rx for this butnI only know couple of choices. There's FS-R8B, Dasmikro 8 Channel Flysky RX. The one in the video which is a Turnigy RX 9X8C which is a rebranded FS-R8B I believe. Quote:
![]() | #4858 |
Newbie Join Date: Aug 2019 Location: Finland
Hi, Seems that I can't find answer to my problem from earlier posts. After completing firmware update I won't be able to calibrate CH1 left direction. It just keeps blinking in calibration mode. The value from steering potentiometer is changing though. Also it seems I won't be able to enter key-test menu where it's needed to turn steering to left. Any ideas? Edit: CH1 readings in calibration menu are from left to right around 350-900, if that matters. Last edited by vqh; 08-09-2019 at 04:19 AM. Reason: Additional information |
![]() | #4859 |
Is it possible to setup a pair of trim buttons to trigger 2 channels?
![]() | #4860 |
Pebble Pounder Join Date: Dec 2007 Location: Cumming
Guys looking to get a gt3c to get the full channel operation (8channels?) which one should I buy?
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
