![]() | #4881 |
That’s working as intended. Yes it can work with multiple receivers, But it only is a single transmitter. If I remember, some dual stick are setup for that, on RC tanks and construction equipment . Big $$$$ Hang up and Drive |
![]() | #4882 |
Quarry Creeper Join Date: Aug 2005 Location: Jefferson City
Yes, JoJo513, that, unfortunately, is the nature of the radio. It will bind to multiple receivers, but when switching models it does not kill control of the previous model's receiver. The bind is not a 100% unique handshake between the radio and receiver. So, unless you actually disconnect the battery or switch the other vehicle off, you will not be able to control the vehicles individually on the fly. |
![]() | #4883 |
Rock Stacker Join Date: Mar 2012 Location: ohio
I’ve been looking at these radios for a 4ws radio and light control. Is there a way to add self centering toggle switch to use for the rear steer switch ?
![]() | #4884 |
Newbie ![]() Join Date: Nov 2019 Location: Tryon
Is there any way to get expo to work on channel 3 for dual esc?
![]() | #4885 |
Newbie Join Date: Jan 2020 Location: Montrose
I hacked my GT3C recently and love it with my dual ESC (HH BR Minis) MOA crawler. I also have rear steer. I currently have it setup to run momentary F/R dig off of the DR button and the rear servo off the CH3 button setup as incremental movement (and plugged into Ch3 on the receiver. My rear ESC is plugged into Ch4 on the receiver. I'm trying to do two things unsuccessfully though. 1. Program the C button on the grip to return the rear steer back to center immediately. Edit Just figured this one out, but every time I turn the transmitter on or exit the REV menu the rear wheels shoot all the way left. No big deal because Incan click the C button and return it to center, but that seems odd. 2. Setup the ST buttons to toggle 4WS, crabwalk, and back to front steer. When I try to use the 4WS function it looks like it references CH4, which is my rear ESC, not my rear servo. Do I have to use CH4 on the receiver to use the 4WS function, or can I change that to CH3 somehow? Thanks in advance. Last edited by charlieboyd65; 05-26-2020 at 10:57 PM. |
![]() | #4886 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
Does anyone know if it would be possible to reprogram "CH3 TRIM" or "-DR+" to run a vanquish dig? What I'm hoping to accomplish: Switch center position (servo is all the way forward) normal operation 4WD Switch forward position (servo is centered) unlocked rear wheels - powered front wheels Switch rear position (servo is all the way back) locked rear wheels - powered front wheels My firmware is 061 according to the global menu. EDIT* For some reason when cycling through the type of channel I want there is no MP1, MR1, MP2, MR2, etc... What on earth? Last edited by GTSLOW; 08-22-2020 at 09:09 PM. |
![]() | #4887 | |
| ![]() Quote:
My memory is abit rusty, but try this Setup Multi-Position: Scroll to End Point, press and hold enter Scroll to P1, press enter Scroll to desired channel (3 for example), press enter Scroll To +100, press enter Scroll to 0, press enter Scroll to -100, press enter Scroll to END, press enter Press back/end afew times Now assign a switch Scroll to Reverse, Press and hold enter Scroll to 3 for Ch.3 Trim, press enter Scroll to MP1, press enter Scroll to BRS so it will reset to default if you long press, press enter Scroll to RE0, press enter (fyi RE1 will reverse the switch) Scroll to PV0, press enter Scroll to RO1 so the multi-positions are sent in a loop Now ch3 trim should control it. It should default to 4WD. The forward/back clicks of the switch will loop through the 3 postions. If you long press forward or back, it will return to 4WD. MAKE SURE TO SET YOUR ENDPOINTS TO ZERO before plugging in your dig servo and slowly increment the end point until the dig is fully actuated. Usually there is an audible noise when the servo binds up, back off a couple clicks from the bind point. | |
![]() | #4888 | |
| ![]() Quote:
Follow up question, I recently hacked another GT3C. Upon initial startup I apparently hadn't fully depressed the power button. So the CAL screen popped up and the radio shut off. Is there a way to re-calibrate everything? | |
![]() | #4889 | |
| ![]() Quote:
Code: Calibrate menu: =============== - enter it by wheel right-turn and ENTER-long - 6 menu items starts to blink (+ 2 arrows if CH3 is potentiometer) - use END or ROTATE to change channels - there is also channel 3 representing CH3 button (for those who will do some 3-position switch/potentiometer modification) > There is 1K resistor connected between CH3 button and +5V, so simply connecting linear potentiometer instead of CH3 button will not work. Usefull results can be done with logarithmic potentiometer 10K which has 1K at half of turn. Or eliminate internal resistor to +5V, connect potentiometer between +5V and GND and potentiometer output instead of CH3 button. - there is also channal 4 representing battery voltage - calibrate as usual (for channel 1/2 left+mid+right and ENTER) > calibrated value will disappear from menu > it is not needed to calibrate all values - calibrate CH3 potentiometer (if selected at global config) > only left + right positions - calibrate battery (it will not be probably needed to use this) > select channel 4 > press ENTER > set your current battery voltage (measure it by voltmeter) > press ENTER to save it or END to no-save - press BACK-long or ENTER-long to end calibrate menu and save values | |
![]() | #4890 |
So I have channel 3 assigned to the "CH3 Trim" switch and it works GREAT for my servo winch. I'm trying to do the same with the -D/R+ switch. I'd like that to be channel 4. However, when I go to the button assignment menu I select "d" which is for the -D/R+ switch and it only gives me these options "CH3, EXB, EXF, EXS, DRB, DRF, DRS, TR2, OFF, MP1, DIG, 4WS, CS3, CS2, SSR, SST, ST3, ST2, ST1". There is no option for any of the other channels. I have set my channels to 6 on the main menu. ** Edit. So I can't seem to get access to anything beyond channel 3. I've gone to the home menu where it shows F 062, scroll to c, and I've tried setting it to 4, 5, 6, 7, 8 channels and I still can't assign anything beyond channel 3. Last edited by GTSLOW; 11-06-2020 at 12:43 AM. |
![]() | #4891 |
Newbie Join Date: Sep 2008 Location: Spain
Try on NAME, Enter-long. Here you can change the number of channels for that model
![]() | #4892 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
Anyone know if RC Addict is still in business? I want to buy his hacked GT3C .. and he shows it on the site .. but you know how it is with business and peoples lives these days with the pandemic, personal issues, etc. He has no email and hasn’t responded to my messenger message. Thanks
![]() | #4893 |
Newbie Join Date: Jun 2020 Location: GB
Has anyone had any success flashing the gt3c with this style programmer? I noticed that some of the pinout are different to what's on the guides. I getting a constant beeping as soon as I ug the radio in. ![]() Sent from my Pixel 5 using Tapatalk |
![]() | #4894 |
That’s what I used. Follow setup precisely, all the proper pins seem to be there. Hang up and Drive |
![]() | #4895 |
Hey guys a little help if possible, since i cant seem to find receivers for the 7 ch radio i bought of banggood and still have a couple of hacked gt3b left, i am now looking for the 8 ch receiver that binds to this radio, cant recall what model it was..
![]() | #4896 |
![]() | #4897 | |
RCC Addict ![]() Join Date: Jan 2016 Location: Kelowna, BC
| ![]() Quote:
*Edit Looks like R9B is the Rx you want for 8ch into a GT3B or GT3C Tx Last edited by QuesoDelDiablo; 12-21-2020 at 10:32 AM. | |
![]() | #4898 |
Thx queso and mike for the help.
![]() | #4899 |
Newbie Join Date: Apr 2021 Location: Canada
Just curious if anyone could help me out with adding the potentiometer for the ch3 button. I know how to wire a pot, I just can't seem to figure this one out, and where on the controller to hook the 3 wires to. Where do I get the 5v from? Is resistor labelled r18 the one you eliminate? The line with resistor r18 that leads to the ch3 button, then to ground, I assume is the channel 3 feed from the microcontroller? I would hook the middle leg of the pot to that line where the resistor is eliminated? Sorry for all the questions, I just can't seem to find the information on how to do this anywhere. Thanks for any help you can give me. |
![]() | #4900 |
Never mind. I got it figured out. I looked up the datasheet and pinout for the Stm8 chip on it, and started probing with my multimeter. I didn't realize that the other side of r18 that went to the button also went to pin 19 on the Stm8. So positive lead of pot to, according to the orientation of the screenprinting, the bottom side of resistor r18, the signal middle lead of the pot to the top side of r18, and the other side to ground. I made the mistake of figuring the housing for the micro USB port on it was a proper ground. It was not apparently, which is what was causing my issue. |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
