![]() | #481 |
Something to note, for those who are using ch3 You need to go into the menu and turn the ch 3 button to OFF, and it needs to be set to off twice...so Long click rev C, enter Off, enter Off, enter Long enter back If you don't do this, ch3, be default, will always start at -100% This is for FW 0.4.x and below. 0.5.0 and above should by default, have the ch3 button set to OFF. |
![]() | #482 | |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
| ![]() Quote:
![]() | #483 |
Just finished a simple mod, cut a small piece of plastic from stock parts and a small screw, about 2mm taller than the original switch, easier to move the switch now. ![]() |
![]() | #484 |
For 0.4.0, and 0.3.2 Alright, just wrote this up in a PM...to setup 4ws and winches ST trim buttons will work 4ws -the it will give from rear only, even mix, front only...just cycle through the postions with the two buttons, you don't have to hold it) D/R will work the rear winch -(switch must be pressed for winch to wind.unwind) and CH 3 Trim will work the front winch -(switch must be pressed for winch to wind/unwind) 4WS -Ch1&3-ST Trim Buttons Front Winch-CH4-CH 3 trim Rear Winch-CH5-D/R switch Activate 4WS mix Long click EPA 4 3 0 NOC Long enter Map the 4WS mix to ST trim Buttons Long Click REV 1 4WS NOL 100 NOR NOO Press and hold enter back Map CH 3 Button to turn crab on/off Long click REV C 4WS SWI NOR NPV OFF Press and hold enter back Map CH3 Trim switch to control Channel 4 Long click REV 3 CH4 MOM Press and hold enter back Map D/R switch to control Channel 5 Long click REV D CH5 MOM Press and hold enter back Last edited by losikid; 11-17-2011 at 04:25 PM. |
![]() | #485 |
![]() | #486 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| ![]() Quote:
Signal on the left, power in the middle, ground on the right (just in case) | |
![]() | #487 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I thought I had this totally dialed but I am now running into one small setup item I can't quite figure out. I did at least learn how to search a specific thread though first. ![]() How does one reduce the dead band on the radio as mentioned in the initial features? I am thinking it might be a part of sub trim but a I am no sure. Thanks in advance. RickM |
![]() | #488 | |
| ![]() Quote:
Right after power on, press and hold enter scroll to 1 or 2 (1 is for st, 2 is for th) press enter adjust to what you want, bigger the number, bigger the deadband | |
![]() | #489 |
Well here is why I ask. I am working on stuff for my MRC. As of right now, if it takes a bit of throw to really start getting a rig in motion then there is a pretty short amount of trigger throw to sort out speed. I am hoping decreasing dead band will give a little bit better speed control under throttle. I did drop to the smallest deadband on the cc sidewinder, and I also dropped the deadband on the radio to zero I also double checked the calibration on the radio. Thanks yet again Losikid. RickM |
![]() | #490 | |
| ![]() Quote:
![]() | #491 |
I will give that a go as well. I am using a rockmafia 16t motor. Great motor.
![]() | #492 |
I have Regulators here, i'll ship out tomorrow. I'm going to work on install instructions here in a little while. Also i have bearings on the way, Should have them next week |
![]() | #493 |
I have a 11.1v 2300mah 35c lipo and like to do a lipo mod, battery's size is 10x4x1.5cm but I'm concern about the "35c", is it OK with radio? Can I fully charge the battery when use in the radio? Thanx! Last edited by kc092755; 08-16-2011 at 08:36 AM. |
![]() | #494 |
Quarry Creeper ![]() Join Date: Apr 2011 Location: Western Australia
hey mate can you tell me how to map the channel 3 trim switch, for a punk dig ,have it working with the dr switch and channel 3 button for reset,buggerd if i can work it out for ch3 trim ![]() |
![]() | #495 | |
| ![]() Quote:
you should be able to just set the ch3 trim switch the same way you set the dr switch | |
![]() | #496 | |
| ![]() Quote:
Set it up just like you did with the d/r switch.... | |
![]() | #497 | |
| ![]() Quote:
Specs: ~~~~~~~~~~~~~~~~~~~~~~~~ The T1450TX-3 lipo pack is an excellent replacement in radios which used 8 x AA cells in flat formation, such as many Futaba or Sanwa models. Bring the world of Lipo technology to your transmitter today! A perfect conversion to Lipo for any transmitter with an 8xAA flat form battery compartment. The pack includes a JST-XH charge port plug, and a Futaba plus a JR style discharge plug! Capacity: 1450mAh Voltage: 11.1v (3S1P) Size: 93x40x14mm Charge Plug: JST-XH Discharge: Futaba & JR ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ All charged up it's at about 12.6 volts and fits right in after I modded the AA battery holder. Cut out the plastic cross brace thingy, unsoldered wires, pulled out all the metal battery contacts for AA cells, drilled hole in end of holder for wires, soldered a Futaba style battery plug (from servo lead extender), plugged it in, tucked all the wires nice and neat, and slid the battery door back in place. ![]() ![]() ![]() EDIT: I took pics when I did mine and will update my Honcho build thread with them, also will post the pics here so you can see how it fits and what to do. Losikid, will your hi-efficiency VR handle the 3s lipo at full charge? Last edited by Natedog; 08-16-2011 at 03:29 PM. | |
![]() | #498 |
For those wanting to max out their battery compartment with a 3s here's one, 2400 mah http://cgi.ebay.com/Venom-3S-1P-2400...#ht_2240wt_654 Its quite pricy though, i've been looking for the no-name brand but can't find it. Edit: I can't promise the above pack fits, as i can't seem to find it on venoms website...i found one but it wasn't the same dimensions. Last edited by losikid; 08-16-2011 at 03:38 PM. |
![]() | #499 |
Vr's have been shipped. I'm working on install instructions
![]() | #500 |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
