08-16-2011, 08:40 PM | #501 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Could you run a 2s lipo instead of 3s with this VR? cheaper battery still better efficiency
08-16-2011, 09:06 PM | #502 |
08-16-2011, 09:49 PM | #503 | |
not sure on the cost http://www.youtube.com/watch?v=4x3GE-qhdlM | |
08-16-2011, 09:56 PM | #504 | |
I bought Motor M4x the other day for the computer, and i have already played a short time, got steering and throttle working. Next i'm going to figure out how to get the switches to control 4 wheel, lockers, low/hi, etc. But i'll tell you what, its pretty fun playing that game with a rc car tx, especially on the big screen (tv). Once i get motor m4x working good i'll pust up my findings. Then i'll buy 1nsane and see if i can get it working on it. Then we can have rcc trail runs | |
08-16-2011, 10:42 PM | #505 | |
I havent played any recent versions but it was pretty fun, there are crawlers, 18 wheelers, cranes,hot rods and rock crawlers http://www.rigsofrods.com/content/? and if you have android this is a simple fun and addictive game with free and paid versions https://market.android.com/details?i...=search_result | |
08-16-2011, 10:48 PM | #506 | |
08-17-2011, 12:01 AM | #507 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Loosing hope in Venom. Have sent back about $1200 in batteries in the last 3 months for cells dying or coming dis connected in my track cars. All in Roar approved cases. Im keeping my hopes up with my hobby king 2200 when it gets here | |
08-17-2011, 12:10 AM | #508 | |
As for batteries, i have something coming in a week or two. It'll be neat if it works. | |
08-17-2011, 01:22 AM | #509 |
How many people have a reamer that goes up to 12mm? Will i need to include a 12mm drill bit with the bearings, for the bearing mod...(have to enlarge a hole from 8mm to 12mm) I'm going to try a 15/32 drill bit when i get the bearings in (in afew days) but 15/32 is about .003 smaller than 12mm so it may not work, i don't think many people have metric drill bits, i know i don't, and i have alot of drill bits, all standard. |
08-17-2011, 01:56 AM | #510 | |
As for the reamer. I have a dubro and a dynamite. Dubro is cheap, kinda short for how steep it is but goes up to 16.4mm. Dynamite is a lot nicer, replaceable tip and has marks in mm on it. Goes up to 13.5mm Last edited by JokersWild; 08-17-2011 at 02:00 AM. | |
08-17-2011, 11:52 AM | #511 | |
Now if i was looking for 15/32" bit, were talking $1 | |
08-17-2011, 07:05 PM | #512 |
FW 0.4.1 has been released. The changes include Code: *0.4.1 () minimum battery voltage set to 6V For 2s LIPO and new VR CH3 key set default to OFF No more accidental winches spooling in on power up added DGR key function to reset DIG mix to centre So you can press the ch3 button to rest your mix to 0 added posibility to select DIG instead of channel number at MultiPosition Had this implemented, so you can have 2 positions to swap between your favorite mix positions easily (0% and 40% for ex) added lap count functions assignable to keys Not much use for us I will be testing these new features tomorrow, if all tests good i'll post up some download links |
08-17-2011, 08:27 PM | #513 | |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
Thanx! | |
08-17-2011, 08:52 PM | #514 | |
When only the last digit changes, models and such shouldn't need to be re setup. Only if the first or second number changes will new models need to be setup so 0.4.0 should upgrade to 0.4.1 without any issues. But 0.3.2 to 0.4.1 will require you to setup new models. | |
08-17-2011, 09:44 PM | #515 | |
Thanx! | |
08-17-2011, 10:04 PM | #516 |
08-18-2011, 06:58 PM | #517 |
How do you remove the wheel? I have the "pod" unbolted from the radio and tire grip removed but cant see where you separate the wheel from the pot and i don't want to force it off because it feels like it would break.
08-18-2011, 07:04 PM | #518 | |
Poke it down into the hole on the center cap... now pry the center cap out. Theres a screw underneath there. | |
08-18-2011, 07:07 PM | #519 |
Here's a vid of my losi...i'm using the gt3b :mrgeen: For those doubting its dual esc capabilities http://www.youtube.com/watch?v=R90Oqc-XfVc |
08-18-2011, 07:09 PM | #520 |
| haha center cap, now that i see it i cant believe i missed it. thanks
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
