08-18-2011, 07:10 PM | #521 | |
oops, wrong attached smiley, oh well | |
08-19-2011, 07:10 PM | #522 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
HOLY WOW....... Austin can you get me a good picture of where the antenna wire solders to the board?? Put in my VR and wire broke at the solder joint. Hard to tell what one it was soldered to. And is it one braided wire or is it like coax with two points to hook to?? Wish it would have just had a plug to unhook it each time. I know it was on RCT somewhere.... still searching it. Figured may help out some putting it here also EDIT////// ok its coax..... looks like center of coax goes to the center of the three spots there and the outer of the coax goes to the outer (opposite the power switch) Third hole to the power button side gets nothing. Correct??? Ok..... i think i got it...... hella small stuff. Had to pull out my fine fine point for my soldering iron. Seems to be on there (no solder bled between). Anyone run theirs with broken antenna and know about what the range is when its not connected?? Just want to make sure all is 100% here. Kinda sketched on running the 1/8 scale ofna onroad with it...... CC 2650 on 6S LMAO. Last edited by JokersWild; 08-19-2011 at 08:26 PM. |
08-19-2011, 09:49 PM | #523 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I am not sure I share your same level of concern as I did this with my kids slash(even though I probably should have). I broke off the antenna, smacked it with some soldier (not knowing it was three wires) and went out in the dark to see how far I could run his truck up the block. I am a little worried about how it will hold up at the local track with other radios running though.
08-20-2011, 02:20 AM | #524 |
Rock Stacker Join Date: May 2011 Location: Fresno
Just got my Losi MOA setup. 3ch Button does rear dig to 4wd, 3ch trim does full front and rear dig, D/R does +/- 20% increments front and rear dig. Using a Novak M2 proportional dual motor speed control. This is gonna be fun. |
08-20-2011, 12:34 PM | #525 |
Here's my pics of 3s battery install. |
08-20-2011, 12:38 PM | #526 | |
08-20-2011, 10:24 PM | #527 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
anyone here using an ESC to control the winch? I finally decided to setup the winch on the Gt3B for a scale run tomorrow morning but my 3racing controller is burnt and heyOKs controller isnt here yet. i decided to use my mamba micro but cant seem to get it setup properly on the extra channels. if i plug it into the RX where a ESC should go it works fine, though with the throttle. when i connect it to another channel it will either spool all the way in/out or not do anything at all. i cant control it at all from the gt3B
08-20-2011, 11:14 PM | #528 | |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Also try programming the esc to the switch, buy turning the esc on with the switch in one of the full positions (which ever works out to be like full throttle). | |
08-20-2011, 11:51 PM | #529 | |
BTW when it was running on Ch2 on the bench i plugged the winch into the micro sidewinder and a 3S lipo and it was awesome . The HeyOK controller I ordered was the high volt one and can take 3s but it needs to be coming off the RX otherwise it will burn up. I dont think i want to set the BEC that high and fry the rest of the electronics haha | |
08-21-2011, 05:53 PM | #530 | |
Obviously servo out on side where the signal wire is and BEC in on the other side. mines off of the D/R switch. straight off of receiver on CH6 long hold on REV scroll to d CH6 NOL 100% NOR NOO Back then done Also there was not 3 wires for the antenna.... there was 2 Last edited by JokersWild; 08-21-2011 at 05:59 PM. | |
08-22-2011, 11:18 AM | #531 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
Hi losikid, When I switch D/R to 60%, the designated wheel barely moving and not moving at all when switch to 80%, not as the wheel speed shown in your video http://www.youtube.com/watch?v=v7dGi...eature=related I set up mixed rate follow your "Dual ESC Mixing Template". Please help. Thanx! |
08-22-2011, 03:03 PM | #532 | |
If you go fast enough on 80% the motor should spin. | |
08-22-2011, 03:06 PM | #533 | |
08-22-2011, 06:52 PM | #534 |
| Im sure it would help out someone...... Ive torn it apart a bunch of times and stupid me pulled top cover and flipped the board around forgetting about it. I guess remind people to pull the top cover and not the board over the antenna Im sure the solders were not on the wire all that well due to the wire just snapped off right at the solder joint. Was easy (easier than i thought i should say) with my small point tip and Trak Power @ 600 deg Just stripped coating with blade..... separated them both and tinned a good deal. Then carefully soldered away
08-22-2011, 07:03 PM | #535 | |
What i did for my radio is cut a slot in the antenna hole, so i can, with ease, pull my antenna in and out so i don't have to worry about the connection. | |
08-22-2011, 07:04 PM | #536 |
Also if anyone needs parts for this radio lmk, i just got a bum tx from hobbypartz and i doubt they'll replace it since i popped the lid open.
08-23-2011, 11:16 AM | #537 | |
Newbie Join Date: Jun 2011 Location: Denver
thanx ps xr10 with rooster... | |
08-23-2011, 11:57 AM | #538 | |
Map CH3 Trim switch to control Channel 3 Long click REV scroll to 3, press enter scroll to MOM, press enter Press and hold enter back Make sure to turn "c" To Off, Off Long click Rev scroll to C, press enter Scroll to OFF, press enter scroll to OFF, press enter Press and hold enter Back | |
08-23-2011, 11:58 AM | #539 |
Here's a picture of the new cable if anyone has been wondering |
08-23-2011, 01:09 PM | #540 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
Have you had a chance to try out the new firmware?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
