![]() | #41 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Do I need this? prob not. do i want this? you betcha! finally decided to order a radio and one of your programing kits ![]() though i still never finished up the 2 T6A conversions haha. I think ill finish up both and sell one and keep the other as a backup for a buddy |
![]() | #42 | |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| ![]() Quote:
I run 3s through a BEC set at 6V, been running smoothly for 3 months. | |
![]() | #43 |
Quarry Creeper Join Date: May 2007 Location: Euless Tx
The 4ws has multiple options including crab and non crab. The winch control works great I'm using dual winches on my scaler and they work wonderfully!. Posted on a POS smartphone :p |
![]() | #44 |
how do you change between front steer,rear steer,crab, and normal 4WS ?
![]() | #45 |
There are multiple links to the manual in the gt3b thread on rctech. It explains all of the settings. I have not messed with the 4ws myself I just know its programmed in the new firmware and I will eventually use it on my super! ![]() Posted on a POS smartphone :p |
![]() | #46 | |
Rock Stacker Join Date: May 2011 Location: Fresno
| ![]() Quote:
![]() | #47 |
| ![]() Im sure there are. Im still on page 36 of 123 skimming the thread
![]() | #48 |
![]() | #49 |
![]() | #50 |
Ok so just looked at latest revisions on the firmware, and now you can use a button such as the ch 3 button, as a 1-8 true position switch. What you do is click it and it'll change position. positions don't have to be in order. Also there's dual esc/servo steering...so for tanks, boats, or something you can use your steering wheel to control esc's to steer. I haven't tested this yet though, just reading the manual while i sit here making 4 position extensions so i can get these hack kits shipped out. Last edited by losikid; 06-27-2011 at 08:35 PM. |
![]() | #51 |
Yea the tank/boat steering was for a project I'm working on. I pm'd psx and he added that to 0.3.1 for us. Posted on a POS smartphone :p |
![]() | #52 |
![]() | #53 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
sent ya a p.m.
![]() | #54 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Had to get it before they hype and supply is gone..... ordered ![]() |
![]() | #55 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
wow that's awesome, seems just as capable if not better than a 4pk for a huge fraction of a price with that update.
![]() | #56 |
i got my kit yesterday and today did the programming it took a couple trys as the 6ch didnt want to work the first try for somereason but i got mostly figured out, just trying to understand how to set it up the mixing for a moa. but did get it to run my punk dig in my losi moa and running my tamiya semi on it with 4 channels. losikid can the esc mixing for a moa be done with a 3ch rx? if not then i guess ill need to order a couple 6ch rxs, just trying to save some $ Last edited by benoj; 07-01-2011 at 04:10 PM. |
![]() | #57 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Just ordered mine thanks bud,can't wait
![]() | #58 |
Flash kit showed up yesterday the radio today. button layout is much more comfortable in my hand than I thought.
![]() | #59 | |||||||||
| ![]() Quote:
So here's the 0.3.2 manual https://raw.github.com/semerad/gt3b/...NUAL-0.3.2.txt First thing you'll want to do for dig is enable it. To do so, it uses the mix section section of the manual Quote:
Ok so now you have enabled the mix, but lets say you want to use your switches for proportional control, dig, or both. You need to go to the keep mapping menu Quote:
Ok so scroll to rev and long click Now the digit to the left represents what key you want to program...1,2,3 are your trims d is your d/r and CH3-C, Back-b, End-E....it also seems you can program the trim keys individually as well when the arrows light up. Now press enter...it will bring you to this section of the manual Quote:
Anyways in the menu you will see a sequence section. It will tell you what your choosing and what its visual indicatpor is on the screen So if were doing dual esc's this is what my steps are and i'll explain them -Long click rev -scroll to 3, press enter -scroll to DIG press enter (selects the DIG function) -Scroll to MOM for momentary press enter (the switch uses momentary control, this will be for instant dig) -(because its mom it skips step rate) -Choose NOR for now, change later if you want to reverse the way it controls it -(it skips opposite reset) -choose PRV (this will return the channel back to your previous mix rate, in stead of an even mix mix) -(It skips Rotate) -Hold enter (to exit out) -Back (to save) Ok now lets say you also want proportional Too So -Long click REV -Choose d -Choose dig -Choose RES (so a long click will reset to center, theres many options) -Select your mix% step rate, i like 10 or 20 -Choose NOR for now -Choose NOO -(skips pre val) -(Skips rotate) -Long enter -Back Ok so now your programmed so the ch 3 trim will control instant dig, and when center it resets back to what ever your mix rate was before you went into dig. And the d/r switch will control your mix rate (proportional) and if you hold it for 1 second either left or right it will reset to even mix. I hope this helped explain the manual in whole alittle bit better. Its quite simple to use once you understand how it tells you to do it. | |||||||||
![]() | #60 |
that makes more sense and i managed to figure it out about 5 min before i read your post. now to just get rid of the punk dig and get another sidewinder
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
