11-23-2011, 07:09 PM | #781 |
Losikid, Just suggestion, make some video's like Harley did with Futaba radio's. I bet that will make it alot easier on everyone. |
11-23-2011, 07:11 PM | #782 | |
I should have them done over my Christmas vacation | |
11-24-2011, 09:24 PM | #783 |
Pebble Pounder Join Date: Jul 2011 Location: Oregon IL
| Tonight I shaved the power button so it was flush with the case so I didn't inadvertently hit it anymore. I chickened out on the polarization film flip mod though..... I want to do it but I'm afraid I'll tear it trying to remove it. Has anyone done it? Losikid what do you think about it? |
11-25-2011, 11:56 AM | #784 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
Sorry if this has been covered but I dont wanna go threw all these pages. The only trouble Im having is when going from forward straight into reverse, my 3rd channel (rear esc) doesnt go into reverse, only the front. It goes into rev once you center and push rev again though... |
11-25-2011, 12:19 PM | #785 | |
11-25-2011, 12:20 PM | #786 | |
Most have options of: -No reverse -Reverse with a pause at neutral (what you have) AKA, "Double pump reverse" -Immediate reverse (what you want in a crawler) Check your ESC settings, if you don't have a manual, go the the mfr website. Dang, benoj typed less & beat me..... | |
11-25-2011, 12:45 PM | #787 | |
Oh geeze I cant believe I missed that lol. That was the problem, was on brake and not crawler brake. Thanks guys. Quote:
11-25-2011, 03:46 PM | #788 |
Rock Stacker Join Date: Jan 2008 Location: Southern IL
Put my order in for one of these bad boys, very excited to see what trouble I can get into with it A.D. |
11-25-2011, 04:23 PM | #789 |
11-27-2011, 07:28 AM | #790 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
| Fire!
After binding my 6ch rx I powered up the tx and then the truck. Immediately it started driving in reverse and the engine was glowing red. Any ideas before I start tearing the truck apart? I made several adjustments/modifications to the suspension etc. while I was hacking away at the radio. If it's nothing to do with the electrical side of things all I can think of is that some debris may have fallen into the windings.
11-27-2011, 08:26 AM | #791 | |
"Glowing red" motor is really bad...... Did you calibrate the ESC to the RX? That could explain the running in reverse when powered up. Hope you didn't fry the motor. | |
11-27-2011, 09:58 AM | #792 |
| When I first started using the fs gt3b with the original 3ch rx I had to adjust the throttle trim heavily one way to prevent it from running as soon as it was powered up. Can you explain a little more about this calibration that you speak of? Also, I had run it in the mud once and got the same smoking/glowing scenario before. After cleaning the engine no more smoke, no more glow. That's what made me think something had possibly gotten into the motor to cause this again.
11-27-2011, 10:40 AM | #793 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
basically you put your ESC into calibrate mode. hold full throttle till it prompts you. then neutral till it prompts you. then full brake/reverse till it prompts the last time and tells you its done. | |
11-27-2011, 11:15 AM | #794 | |
Most are: Throttle trim to "0" (including subtrims) Throttle EPA's to 100% "May" need to "reverse" the throttle in the TX Hold full throttle, power up ESC (plug in battery), wait for tone, hit full reverse, wait for tone, go to neutral and wait. You're done. Some have a button to start the process, etc. Find your ESC manual (or online), read & go do it. | |
11-27-2011, 01:01 PM | #795 |
Newbie Join Date: Apr 2011 Location: Prescott Valley
Is there any one in AZ that can do this mod?
11-27-2011, 11:13 PM | #796 |
Rock Stacker Join Date: Nov 2011 Location: Spokane
Ordered my mod. What is a good soldering iron to do this with?
11-28-2011, 07:16 PM | #797 |
| Well if you don't already have an iron, this one would be the best bang for the buck. Soldering Station Variable Temperature 50W - Analog (AT936B) - SparkFun Electronics and it'll do anything else you need |
12-01-2011, 06:01 AM | #798 |
Broke the board in two, and i get : error : Cannot communicate with the board. Wrong board selection or check board power supply or check that a previous session is closed. Error : < PROGRAM MEMORY programming failed." |
12-01-2011, 09:28 AM | #799 |
| Have you by chance read the 2nd post on this thread? I think i linked to the post where i explain what todo if you so happen break the board in two (which i don't recommend)
12-01-2011, 10:49 AM | #800 | |
Edit: I broke the board in two but i was getting the same error before i did it btw. Last edited by cartronicshn; 12-01-2011 at 11:20 AM. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
