12-02-2011, 10:36 PM | #821 | |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Very comfortable to handle, I put a 2S lipo in mine, deans plug...so I can use any battery I have in my stable...well all but the big lipos, and it is really light..I am going to get another one for my wife....the only thing I really don't like is the position of the wheel, I wish it was closer to the face plate, not down and out | |
12-02-2011, 10:59 PM | #822 | |
I'm going to be working on a new trigger mechanism and some new buttons for the ch3 trim and d/r switches and the ch 3 button...mostly i'm just going to rais them up so their easier to switch. The buttons will probably be delrin. Trigger may be delrin or aluminum. And i'll be going to a 60/40 setup, instead of keeping the 70/30. Make the finger slot abit smaller, as i've seen complaints about that gap. Usually the fix is some fuel line. | |
12-03-2011, 12:54 PM | #823 |
| ATTENTION It turns out i received afew bad programming boards in my last order, I'll be contacting everyone from orders 192 and up that i have shipped a hack kit to. Some have good boards, some are bad. If your computer is telling you a error that the USB device has malfunctioned and/or in stvp that it can't communicate with device, Please email me as soon as possible, my email is losikid@overkillrc.com Thanks |
12-03-2011, 12:56 PM | #824 |
Another way to know, is if there isn't a green led flashing on the bottom half of the board.
12-04-2011, 09:08 AM | #825 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
When I set up my winch on ch3 trim or d/r there is constant power to the winch. Other than that the winch works properly. On the ch3 trim channel the winch slowly unwinds without touching the trim button and on the d/r channel the winch slowly winds. Any thoughts on what I may have overlooked?
12-04-2011, 09:32 AM | #826 | |
I have no clue, I'm just suggesting. | |
12-04-2011, 10:14 AM | #827 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
Well, in my case the rear axle is for ch3. When I went to rev menu and chose ch3, the motor started spinning immediately. After I calibrated the esc, this thing has gone. So, may be, this is an issue to be checked. Thanks to Charlie and losikid. |
12-04-2011, 10:18 AM | #828 | |
i'd suggest going into the sub trim menu (enter long on trim) and adjust the trim to the channel your using so there is no drift. Also getting a HeyOK no drift controller will help solve your problem | |
12-04-2011, 10:19 AM | #829 |
| Ummm, what was your problem again?
12-04-2011, 11:05 AM | #830 |
When you go to reverse menu and choose chn 3, the axle starts spinning instantly. Fixed with calibration. Also had to turn the reverse on to stop it spinning and calibrate.
12-04-2011, 03:29 PM | #831 |
| Right you were. However The trim was set to 0 when the issue was occurring. I dialed it down to -35 to make it legit.
12-05-2011, 01:49 PM | #832 |
| That appears to only have been a temporary fix. The next time I turned the radio on I had to dial it down even further before it stopped winding. Anyone else familiar with this?
12-05-2011, 03:04 PM | #833 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Had this same issue with the stock controller. Went to a speed controller to control the winch, and haven't had an issue since. Just seems to be something with those stock controllers 'cause it happened with my spektrum controller as well.
12-05-2011, 06:46 PM | #834 | |
Winch Controller for Radio with Three Position Channel Winch Controller for Radio with 2 Position Third Channel Higher Voltage Winch Controller | |
12-06-2011, 04:13 PM | #835 |
I just got a new order of programmers in. The packaging has changed abit, so i'll make sure the board hasn't changed and my instructions are still valid It will take me a day or two to get caught up on all orders past due (because of this faulty programmer dilemma ) Thanks for everyone's understanding on this situation |
12-06-2011, 05:19 PM | #836 |
Rock Stacker Join Date: Jan 2008 Location: Southern IL
No worries man! I'd rather wait and have good QC than get junk in a hurry A.D. |
12-06-2011, 06:27 PM | #837 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
im intrested in this radio... but ive heard theres a glitch when next to a spektrum radio? i have the word from good source..there were 4 of the fly skys and the rest mainly spektrum..when the rigs with flysky equip rolled up close to rigs with spektrum equip,the spektrum rigs started shaking and glitching..? has anyone else noticed it? ive heard theyve banned them from on-road racetracks as well. im not dissing the radio, just checking out all rumors before i buy. |
12-06-2011, 06:56 PM | #838 | |
But, at the same time why does spektrums high dollar system cripple by a pretty cheap system. Just proves how secure their signal really is. | |
12-06-2011, 07:26 PM | #839 | |
truth! | |
12-06-2011, 07:38 PM | #840 |
| Never heard of any radio being banned, unless its a air only freq radio....and
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
