Thread: GT3B Hack Question and Answer Thread
Old 01-27-2012, 10:55 PM   #1081
Got Worms?
Default Re: GT3B Hack Question and Answer Thread
Originally Posted by Krawler23 View Post
Hey losikid kid when i turn my radio on, after my model name there is a voltage. Is that the cutoff or what? If so what should it be set at? Thanks
that should just be what voltage your batteries in the tx are at
losikid is offline   Reply With Quote
Old 01-28-2012, 09:40 AM   #1082
I am just using double a's for now, what are 8 of those supposed to be set at? Thanks again
Krawler23 is offline   Reply With Quote
Old 01-28-2012, 11:56 AM   #1083
Got Worms?
its not a setting its a volt reading. It tells you how many volts your batteries are at
Old 01-28-2012, 12:43 PM   #1084
Oh ok haha thanks
Old 01-28-2012, 05:50 PM   #1085
Losi Kid, I just got the hack done on my radio. When should the low voltage alarm come on? Mine was flashing at 10v and while I was trying to get it setup it started ringing at 9v
Never mind I had some bad batteries. I gotta get new rechargeables.
Mutant_Xj is offline   Reply With Quote
Old 01-28-2012, 06:13 PM   #1086
Got Worms?
yea, i think the default is 9.2 volts...it can be ran down to 6.5 if AA's can go that low
Old 01-28-2012, 06:27 PM   #1087
Are there any write ups on setting up this radio for a scaler? I'm reading through the manual txt and it's about as painful as learning Japanese. I'm trying to figure out how to get Dig setup on my SCX10 with a VP dig. What does each button control? the CH3 button didn't do anything when I pressed it and I have the dig servo plugged into that channel. I'm lost at this point.
Old 01-28-2012, 06:32 PM   #1088
Got Worms?
you have to assign a switch to control channel 3. so for instance to assign the ch3 trim to control the 3rc channel in a non momentary 3 postion you'd go
Scroll to REV, Press and hold enter for 1-2 seconds
Scroll to 3, press enter (selecting ch 3 trim switch)
Scroll to CH3, press enter (selecting the function, in this case channel 3)
Scroll to NOL, press enter (selecting the way the switch acts, this is just a normal no momentary 3 position)
Scroll to 100, press enter (this is the step rate (%'s changed per click)
Press and hold enter for 1-2 seconds, then press back/end afew times. (saves and exits key mapping menu)]
you're done! (then go into epa menu and adjust epa's for your tranny)
Old 01-28-2012, 06:49 PM   #1089
I just did what you typed and the dig servo moves with the throttle
Old 01-28-2012, 06:57 PM   #1090
Got Worms?
You must have turned on the dig mix somehow...go into long click epa, scroll to d, chance it to OFF
Old 01-28-2012, 07:19 PM   #1091
Worked! thank you. I think this is going to be a little work figuring out what does what and how to program it. The manual is too hard to follow and I didn't find anything where someone spelled everything out for us.
I'm hoping to get a winch and lights setup eventually too. I want the winch setup on the -D/R+ switch and a set of lights to the CH3 button. Those with the dig would be 5 channels, if I wanted to use the sixth channel I would then have to give up either the ST trim or the TH trim, correct?
Old 01-28-2012, 07:22 PM   #1092
Got Worms?
yea, for the 6th you'd have to give up st or th trim. but you can still trim thru the trim menu. No big deal
Old 01-28-2012, 08:21 PM   #1093
Well played with radio settings and got a somewhat idea how menu works. One thing thou, its said goes down to 6.5 volts for low warnings? I can dial my radio to 6v?? Or you saying warning only works down to 6.5v not 6v on menu?
skinner is offline   Reply With Quote
Old 01-28-2012, 08:23 PM   #1094
Got Worms?
the new voltage regulator is only good down to 6.5 volts, so anything lower than that funky stuff will happen
Old 01-29-2012, 07:44 AM   #1095
Long click REV
scroll to 3, press enter
scroll to CH3, press enter
scrol to NOL, press enter
scroll to 100, Long enter
Long click REV
scroll to d
scroll to CH3
scroll to MOM
Log click enter, and press back/end afew times.
Your done, plug your punk dig into ch3 on the rx
ok this works great but is there a way to reverse the direction that you have to push d/r and ch3 trim
right now i have to push forward to get rear dig and backwards to get front. it would feel more natural the opposite direction.
thanks for the awesome products and support
nappahdog is offline   Reply With Quote
Old 01-29-2012, 08:26 AM   #1096
I just reversed the servo and set the end points.
Old 01-29-2012, 09:11 AM   #1097
Got my hack finished last night. I'm very happy with the results. I did run into a few complications though when I was working on it. I wanted to pull the power button off as described in the instructions and ended up breaking the power switch and had to make a trip to Radio Shack for a new one. While there I got a 5v 30ma led that I wired directly to the new voltage regulator (hope that's correct). I also did the the following:
1. Header for programming
2. New power switch
3. LED
4. VR
5. Bearing mod
One thing I notice is the steering servo glitches the other servos. I remember seeing the steering servo be a little glitchy before the mod so I'm guessing it's the same. I'm wondering if I have a bad steering servo. The reason I wonder is it makes channel 2 and 3 go crazy when you steer back and forth from time to time. Moving that servo to any other channel it minimizes the effects. Getting rid of it reduces it a bit and I'm back to the steering servo just buzzing a little at neutral.
Thanks again. Pictures to follow.
ik632 is offline   Reply With Quote
Old 01-29-2012, 09:32 AM   #1098
What servo?
Do you run an external BEC to it (if it's over ~200inoz)?
Did you try another servo in the steering port to see if it's a RX issue or the servo?
Charlie-III is offline   Reply With Quote
Old 01-29-2012, 11:07 AM   #1099
Can anyone help me out real quick I'm on my way to a comp right now and can someone tell me how to set up a 3pos third channel on my controller.
the_ocho is offline   Reply With Quote
Old 01-29-2012, 11:24 AM   #1100
Post 408 may help....
Also look at page 1 of this thread.
[Are you sure you couldn't wait just a little longer to ask this question.........?] LOL
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
