Thread: GT3B Hack Question and Answer Thread
Old 02-06-2012, 03:51 PM   #1121
Default Re: GT3B Hack Question and Answer Thread
I just ordered on of these. Has anyone tried the Rx past the 6.5v input stated? Just curious.
y2kgtp is offline   Reply With Quote
Old 02-06-2012, 05:01 PM   #1122
Got Worms?
I've ran mine off a 2s lipo...although i did the same thing with another one in my moa and it burnt up within 30 minutes. So it may be only some rx's don't like the higher voltages
losikid is offline   Reply With Quote
Old 02-06-2012, 05:03 PM   #1123
Got Worms?
Just so ya'll know, i'm going thru a server/hosting change and if you need any of the files i've posted, make sure its overkillrc.webs.com/... instead of overkillrc.com/...
Old 02-06-2012, 08:55 PM   #1124
Not yet, but I would hesitate running any more voltage through the RX than needed.
If you want to run an external BEC for servo power, I would run it direct to the servo & leave the RX out of it.
Some of the RX's have very thin board traces, thus a high load will likely burn the traces off the board inside.
Charlie-III is offline   Reply With Quote
Old 02-06-2012, 09:17 PM   #1125
Thanks. I usually just run 6v to the rx, but a
Servo I am planning on running can take 7.4v. I'll look
To see how I can direct power it.
Old 02-06-2012, 09:52 PM   #1126
Alrighty got my 8 spoke wheel, looks killer!! One thing how does original wheel come off before I make a boo boo?? Supposed to remove 3 Philips and unsrew wheel from inside?
skinner is offline   Reply With Quote
Old 02-06-2012, 09:58 PM   #1127
Got Worms?
You have to pull the center cap off...is a pita todo it to make it look good, but unless you want to save the center cap i'd just drill a hole in it and use pliers to pull it out.
If you do want to save the original wheel and cap, you have to take a thick needle or some sort of thin and hard steel, stab it into that little hole on the bottom and try and pry it off.
See my bearing mod instructions
Old 02-06-2012, 10:07 PM   #1128
Gold Star Baby!
redrokin00XJ's Avatar
I run my CC BEC at 7.4v and I run it directly to my servo and the only wire going to the RX is the yellow signal wire.
redrokin00XJ is offline   Reply With Quote
Old 02-06-2012, 11:54 PM   #1129
Originally Posted by losikid View Post
WOW, why such a big button? wouldn't it be ideal to make a more low profile power switch?
miketanct over at rctech made a fantastic hack for the power button.
Making it flush keeps it from getting inadvertently pushed and just looks Sic!
It's A Super Easy Hack.
It took me about five minutes to open case, figure it out, make the mod, and seal her back up.
Just open the case, pull button straight off the switch, cut about 1/4 to 3/8 of an inch off the inside edge of the button. Push button back on switch and close it all back up.
Note the location of the small notch on the inside edge of the button before you modify the button. You will need to remake this notch on the new inside edge of the button after cutting it. This is so that when you push the button it clears a tiny resistor on the board.
I also Highly recommend making the super easy backlight mod as well. It makes it visible in daylight...novel concept. Just peel the polarized film over. takes 30 seconds!
BELADOG is offline   Reply With Quote
Old 02-07-2012, 08:06 AM   #1130
Are any of you having issues with it losing settings when off for some time? I have the steering trim I set to about 10 to the right and it resets back to 0 when it's off for about a day. I'm wondering if it has anything to do with the power switch issue. The stock is a DPDT (double pole double throw) where it's really just a SPDT (single pole double throw) where the left and right are both common to each other. I'm wondering if it needs to roll back to the other side to store settings while off though. Any ideas?
ik632 is offline   Reply With Quote
Old 02-07-2012, 08:08 AM   #1131
I'm actually making a servo/bec harness for mine. You take two female ends and one male end, just wire the +/- up between the females, and the yellow to the yellow on the male. Don't connect the +/- to the male.
Then the male plugs into the receiver, the bec into one female and the servo into the other. This will send power only to the servo then signal from the receiver.
Let me know if you guys need a diagram and I'll sketch one up quick.
Old 02-07-2012, 08:16 AM   #1132
BELADOG - kool thanks for sharing. Where ya get the film thou?
Old 02-07-2012, 02:56 PM   #1133
I think it was in one of the other threads, you actually pull off the very top layer from the actual LCD, then stick it on the back side of the window in the case. This essentially flips the polarizing and you get the reverted characters.
Old 02-07-2012, 02:58 PM   #1134
I'd like to see that, as I will have a servo that takes 7.4v
Old 02-07-2012, 05:42 PM   #1135
Got Worms?
Have you seen this
Receiver bypass adapter
Old 02-07-2012, 06:15 PM   #1136
Got Worms?
Hey guys, i think i've found a good lipo for this
GForce 2700mAh 7.4V LiPO Transmitter Pack (DX
I think you can shove two of them into the battery box supplying your radio with 5400ma's of JUICE.
Old 02-07-2012, 08:32 PM   #1137
Have you seen this
Yeah, that's what I'm making. That's a little shorter. I do like the idea of adding the ground wire to prevent glitching too.
Old 02-07-2012, 10:56 PM   #1138
Thanks but not my hack. I found it on RCTECH. pretty sure its here as well.
The Polarized film is already on the lcd
You peel it off. Its a PIA to get off (just really slow)
Dont worry too much about the sticky residue. I spent about an hour with goof off then realized you dont see it anyway.
turn the radio on and hold the film over the lcd. You can flip it over and see the difference. It's pretty incredible. Looks like the Futaba 10C once flipped.
Then you can either just set it on top of the LCD and put the case back on, or, if you are worried about it sliding, just use some clear Scotch tape to hold it down.
Old 02-07-2012, 11:00 PM   #1139
I did two radios with this mod, and the first one went fine, but the second one came off without the adhesive, so I had to just tape that one to the window. So, be careful, and go slow.
monkeyracer is offline   Reply With Quote
Old 02-07-2012, 11:14 PM   #1140
if the glue stays on the film or the glass on the lcd you can use goof off. It takes a bit but it will come off.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
