02-19-2012, 09:37 AM | #1221 | |
Newbie Join Date: Feb 2012 Location: Montreal
| Re: GT3B Hack Question and Answer Thread Quote:
If I understand correctly, they are not proportional channels then? I ordered the six channel version, I am assuming only throttle and steering are proportional, the extra 4 channels are all for switches but no possibility of using a pot? Bummer! I hope that further firmware developments will fix this. | |
02-19-2012, 10:26 AM | #1222 | |
but it has more than just 2 and 3 pos switches...what setup would you need more than one pot for? | |
02-19-2012, 02:35 PM | #1223 | |
The extra channels I will use for lights or perhaps a plow. They don`t require a proportional channel so it`s not an issue. Correct me if I am wrong but I am sure lots of people will like having a full on proportional channel they can do whatever they want with. I can think of multiple applications other than panning a camera. Unless switches alone permit doing what a pot would do, panning left and right (proportionally) then recentering when finished, a pot is a necessity for such a feature. | |
02-19-2012, 03:08 PM | #1224 | |
02-19-2012, 03:46 PM | #1225 |
Newbie Join Date: Feb 2012 Location: Lumberton
Thanks guys, now I understand how the mix works, and it turns out I had it working fine the whole time. It was not the double tap on the reverse that was preventing me from doing the opposite rotation, it had not occurred to me that that would take place at full throttle. I can tap it once in reverse, turn the wheel to the stop, then give it full forword or full reverse, and it will sit there and spin like a top. After taking a brief look at calc.c I also understand now why steering is so sensitive, and what the D/R setting is all about. Apparently, it mixes the steering in at 200%, which would seem to indicate that with full throttle and 50% steering, one track would come to a stop. So, it looks like the thing to do is to use D/R set to 100% when I want to spin, and some lower value for normal driving. I'm pretty happy at this point, and I see myself with three choices, all of which are acceptable. I can use it as it is. I can use an external mixer. I can learn a little bit of C programming and rewrite the mixer to work the way I want. My laziness suggests using the first choice, but I very much like to get my own way, so I may very well go for the last choice. This seems to be a really great radio, I thank PSX and losikid for that Ed |
02-19-2012, 06:24 PM | #1226 | |
Quarry Creeper Join Date: Feb 2012 Location: SAN DIEGO
Many crawlers and scale drivers that require multiple proportional channels use standard 4ch radios like we use with our aircraft. It is very simple to modify a 4ch+ aircraft radio with a wheel, and if you wanted, or felt you Needed to, you could also mount a trigger on the back Lol. (seen it a bunch) Any channel on say, a Futaba 4EX (very inexpensive 4ch) are already wired with potentiometers...two on each stick Lol. You can pan and tilt with no mods at all. Many 6ch radios use "slider" trim tabs on either side of the cases for flap control. These can be programmed easily to control your throttle channel if you like. Or use the left stick with a ratchet for your throttle and right stick for pan/tilt. You then have a free channel on the left stick for left and right steer or front/rear steer. A few years back (20) pistol grips did not exist and we were all using 4ch two stick radios to drive. I still think if you try a switch for your pan you would like it and find it more than adequate...and comfortable. But you wont know till you try ; ) you could use the d/r switch on the handle. At center its center. a fwd press for right and a rearward press for left maybe? There is a return to center feature as well you could enact. Last edited by BELADOG; 02-19-2012 at 06:30 PM. | |
02-20-2012, 10:48 AM | #1227 | |
This is a cool project! | |
02-20-2012, 12:28 PM | #1228 |
Rock Crawler Join Date: Feb 2007 Location: Lorain
Ordered a radio from you last night. Looking forward to receiving it. Thanks for the hard work!
02-20-2012, 04:17 PM | #1229 |
Newbie Join Date: Nov 2011 Location: lakewood
i am looking for three radios and recivers for my three scx10s, i want to run them all at the same time and plan on upgrading to have dig units, winches and 4ws, would three of your radios and recivers be able to work together and do all of that, with out having issues, i am thinking that 6 channals each would be good.
02-20-2012, 04:29 PM | #1230 | |
02-20-2012, 04:46 PM | #1231 |
what does the radio look like, i havent seen what it looks like and i searched gt3b and all that comes up is the fs-gt3b, is that the right one, how do you give the controller six channals?
02-20-2012, 05:10 PM | #1232 | |
He has a "hack" that greatly expands the capabilities of the radio. For the price (hacked) it can do pretty much anything you need for a crawler. I am currently playing with one, I am late on posting pictures comparing it to a Futaba 3PM-x & a Futaba 4PL. | |
02-20-2012, 06:23 PM | #1233 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
Gave it a go and bought one and I am NOT regretting it. I immediately set out to put all six channels to use, and I've done it! No build thread, but this is just about the radio, eh? CH1 Steering (HiTec 645MG) CH2 Throttle (Novak 18.5 Brushless) CH3 Dig - 3 position on the CH3 Trim (HiTec 645MG on a RC4WD 2-speed dig tranny) CH4 2-Speed - 2 position on the CH3 button (see above) CH5 Front winch - momentary on the CH1 Trim (HiTec 645MG, converted) CH6 Rear winch - momentary on the CH2 Trim (HiTec 645MG, converted) ...with some lights thrown in to boot! I guess I better get on a pic thread now. :/ |
02-20-2012, 10:31 PM | #1234 |
so, do you not have any control over trims after this?
02-20-2012, 10:32 PM | #1235 |
| Re: GT3B Hack Question and Answer Thread |
02-20-2012, 10:47 PM | #1236 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
via taptalk on my G2X with cyanogen mod 7 | |
02-21-2012, 02:20 PM | #1237 |
Which setting do I use below to reverse the direction of the trim? I have it set so I pull back on the bottom one and it gives me front dig (I didn't like pushing forward because it was uncomfortable, pulling back is easier for me). Anyway, I want to reverse the direction of the bias so I can pull back for more rear and push forward for more forward, while the other switch is still inverted. Would I set the one below to REV (marked with an arrow)? Code: Dual ESC Mixing Template: (0.3.2 and 0.4.0 fw's) Ch3 trim-Momentary 3 postion dig D/R-Bias with 20% step rate Turn radio on press enter scroll till E. Points highlighted Press and hold enter for 1.5 seconds E. point should now be blinking scroll so "d" is blinking (far left) press enter scroll till 3 is blinking press enter make sure 0 is blinking, if not scroll so it is Press and hold enter for 1 second Scroll so REV is highlighted Press and hold enter for 1.5 seconds Rev should now be blinking Scroll so 3 is blinking press enter Scroll so DIG is blinking press enter scroll to MOM press enter Scroll so NOR is blinking press enter scroll so PRV is blinking press enter scroll so d is blinking press enter scroll to DIG press enter scroll so RES is blinking press enter scroll to 20 press enter scroll so NOR is blinking <----- change this to REV??? press enter scroll so N00 is Blinking press enter press and hold enter for 1.5 seconds press end |
02-21-2012, 05:05 PM | #1238 | |
Was you afraid to try it? | |
02-21-2012, 06:58 PM | #1239 |
I actually tried it before I came back here to check so I guess I wasn't afraid . It seems that up to about 20% I have good mix and dropped the percentage down to 5%. I'm thinking I might go the next step down too. I have some driving tomorrow afternoon so I'll get some good tuning time. I need to re-read the instructions again that were posted to understand the other settings more. |
02-23-2012, 11:15 AM | #1240 |
Quarry Creeper Join Date: Aug 2009 Location: here
I need help. I want to setup CH 4 for a three position servo and using the -D/R+ button, Channel 5 to control a winch using TH Trim buttons, and CH 6 to control light on and off using a servo board to power LEDs and using the CH3 button |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
