03-01-2012, 08:44 AM | #1261 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: GT3B Hack Question and Answer Thread
Bump for a fantastic vendor, excellent support and a great product. I have two of the fully modded GT3B's and love them! I was very skeptical about using a modified but over all cheap transmitter. I thought it was a huge step down from my Spektrum. I was wrong. The GT3B has done everything I have needed it to do, and Austin's support has been top notch. I have over ten receivers now for the two transmitters. The receivers are priced so ridiculously low, it's easy to have multiples. I also was able to fit a Sky Lipo, 40C, 1600mah 2S lipo in the battery box to power the transmitter. Super light weight and it runs for days! Thank you Austin for making this great product. |
03-01-2012, 09:35 AM | #1262 |
Pebble Pounder Join Date: Feb 2011 Location: Burnaby, BC
I am super stoked to order one, should be doing so within a week or two if things work out like they should. Hopefully it can get to me in time for my comp so I can get dig setup, but we'll see when I actually am able to order it!
03-01-2012, 04:04 PM | #1263 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Better than using a 3r and wantamix? | |
03-01-2012, 09:39 PM | #1264 |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
Hello guys, And thank you Losikid, I received my TX today so super fast shipping. I looked on the web and here but no answer....I m sure answer is here but cannot find it because 1200 posts.... My config: Combo Castle creation mamba max pro and 2400 kv motor. Lipo 3 cells Servo Savox. TX flysky GT3 B and RX 6 channels. To bind: Bind plug in channel BAT ESC channel 1. TX off Turn ESC on and red light on RX and bips Red light s blinking in RX Push bind button on TX off and turn it on. Solid red light Turn off ESC Remove binding plug Turn TX off. Two different things happen: I plug ESC into channel 2 and servo into channel 1. Turn TX on Turn ESC on and red light blink one time and that s it....nothing works. I rebind and sometimes everything works but not good. Steering servo works but not properly, a lot of interferences , it turns but not directly, left right left and finish to reach the position I want. There is some interferences on the motor when I do steering, no throttle but when I steer, motor turn a little bit and stop..... I m pretty sure I do something wrong or there is a setup wrong. For info I tried on two different model on the TX and they have stock seting... Help my guys and sorry to ask like all newbies the exact same question.... --- I am here: http://tapatalk.com/map.php?da31x0 Sent from my iPad using Tapatalk |
03-01-2012, 10:24 PM | #1265 | |
If i sent ya a dud lmk | |
03-01-2012, 10:34 PM | #1266 | |
--- I am here: http://tapatalk.com/map.php?ynrh11 Sent from my iPad using Tapatalk | |
03-01-2012, 10:42 PM | #1267 | |
03-02-2012, 04:17 PM | #1268 |
My problem is maybe a glitch problem....l --- I am here: http://tapatalk.com/map.php?t05v2x Sent from my iPad using Tapatalk |
03-03-2012, 01:36 PM | #1269 |
Pebble Pounder Join Date: Dec 2011 Location: Texas
Losi. Any way yo use the third channel to power on and off a led controller? Sent from my SCH-I500 using Tapatalk |
03-03-2012, 02:40 PM | #1270 | |
--- I am here: http://tapatalk.com/map.php?1fwqov Sent from my iPad using Tapatalk | |
03-03-2012, 05:04 PM | #1271 |
Newbie Join Date: Dec 2010 Location: Tooele
I love this radio!! My only complaint is the backlight.... Not Losikids fault though! My hack is working great, I ditched a DX3S for this setup and love it! My only question is, with all of the firmware flashing and programming, wouldn't there be a way to change the backlight settings on the radio? I think this is definitely something a lot of people would probably be very interested in.
03-03-2012, 06:13 PM | #1272 |
the only setting for the backlight currently is how long it stays on currently
03-03-2012, 06:17 PM | #1273 |
I understand that. But they are able to change all of this stuff in the firmware, why not change the firmware to allow for a longer backlight setting? I would imagine that it is set in the firmware of the radio....
03-03-2012, 06:26 PM | #1274 | |
I'm guessing the RX ground or an external BEC? | |
03-03-2012, 06:29 PM | #1275 |
| Re: GT3B Hack Question and Answer Thread so you want the backlight to stay on longer? to do that hold the enter button and scroll to L i believe and it will have a # with s after for the number of seconds its on, and turn it up
03-03-2012, 06:35 PM | #1276 |
Awesome!!! Thanks benoj! I have left my radio on, twice now, while working on my truck and then walking away. I've gone through 16 AA batts so far... I really need to do the voltage reg mod and get a lipo in there.
03-03-2012, 06:55 PM | #1277 |
no problem. im just using rechargeable AA's in mine since the gt3b came out, i believe there is an inactivity alarm that will go off if you leave the radio on with no use after a set time if you again go hold enter scroll to A and set the time u want the radio to be inactive for till the alarm goes off, i have mine set to 10min as ive done the same thing and when it happened kept wondering what the faint beep was from (batts were so low the alarm was barely able to be heard when i got home from work).
03-03-2012, 08:29 PM | #1278 |
I'm finally futzing with mine. Issues that make it "more interesting": 1-New to me rig 2-Novak M2 dig 3-New radio......finally figured out the RX was not bound to the TX..... I'm just looking over info to make sure I did things correct, but I can only assume ESC is working correctly (since it's used). Yes, I used the template on page-1. Last edited by Charlie-III; 03-03-2012 at 08:32 PM. Reason: added info. |
03-03-2012, 08:35 PM | #1279 | |
03-03-2012, 08:38 PM | #1280 |
| Re: GT3B Hack Question and Answer Thread |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
