![]() | #121 |
If you're getting an error message "STVP GUI has stopped working" or STVP shuts down when you click program current tab Download this patch, and run the application, this should solve your problems http://www.overkillrc.com/GT3B/STVPI...ck24_patch.zip |
![]() | #122 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Ugh, installed the patch. Rebooted. I get the same problem, "STVP GUI has stopped working" and then it closes.
![]() | #123 |
![]() | #124 |
Tried as admin and not, tried XP compatibility mode and normal. Board Broken in 2. radio off.batteries in. plug in programer to radio, then to PC. open program. load firmware. but once i click program current tab it gives me the error and crashes. |
![]() | #125 | |
| ![]() Quote:
Also try to turn off your firewall, as windows is shutting it down because it thinks its a virus or malicious activity. | |
![]() | #126 | |
| ![]() Quote:
![]() | #127 |
| ![]() The flashing green led was not, but there is a red led, when that red led lights up that means its connected with stvp
![]() | #128 |
Ahh ok, I havent seen the red LED yet haha. turning the firewall off didnt help. why is it always the simple stuff that gives you the most damn problems? this is frustrating
![]() | #129 | |
| ![]() Quote:
This is vpc (virtual pc) with xp mode, i think it'll open xp in 7, this may allow you to run the st link http://www.microsoft.com/windows/vir.../download.aspx you may have to get on craigslist and buy an old laptop for 20 bucks... | |
![]() | #130 |
If you don't have 7 pro or ultimate, then read thru this, although you'll need a xp disc http://www.howtogeek.com/howto/11060...ons-and-vista/ |
![]() | #131 | |
| ![]() Quote:
![]() | #132 |
Im running W7 Ultimate 32bit
![]() | #133 |
ok, since you have ultimate it'll let you downloade vpc with xp...for users with home or starter read the second link i posted http://www.howtogeek.com/howto/11060...ons-and-vista/ it will require a xp install disk, with code, but it won't require installing another hd, or opening your computer, or anything,\. |
![]() | #134 | ||
| ![]() Quote:
http://www.vmware.com/products/player/ Either of these allow you to install and run a virtual xp machine on your Win7 machine, don't need any other drives, partitioned drive etc. ![]() Last edited by Natedog; 07-08-2011 at 01:23 PM. | ||
![]() | #135 |
![]() | #136 | |
| ![]() Quote:
![]() ![]() Last edited by Natedog; 07-08-2011 at 05:02 PM. | |
![]() | #137 |
Rock Crawler Join Date: Dec 2005 Location: houston
Ok, got the radio all programmed and set up to run my 3 ch punk dig. I am having an issue with it saving my trim settings when turning the radio off. Each time I turn it off and back on the trims reset to "0", am I missing something with saving the settings to the model memory. Before the new firmware you had to select "enter" when you adjusted trim so it would save, however after the update hitting enter just takes you back to the main screen, its supposed to save automatically. I have read the manual several times but cant find any info. Any ideas?
![]() | #138 |
I'm also having the same issue with the trims. Every time I turn the radio off they all reset to 0. Very annoying to say the least. Also, is there any software that doesn't tie the expo to the total servo travel? The ones I've tried, as you dial in the expo, the servo has less travel. |
![]() | #139 |
Im away from my radio right now, till Mon evening...but try using the back button till home screen. Or try using the sub trim (long enter on trim I think)
![]() | #140 | |
Rock Crawler Join Date: Oct 2006 Location: Fernley
| ![]() Quote:
Also, does any one know if the large splice thing on the 6 channel rx's has to stay or can it be cut off without any problems? | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
