Thread: GT3B Hack Question and Answer Thread
Old 05-22-2012, 03:33 PM   #1601
Default Re: GT3B Hack Question and Answer Thread
THanks!!
gtxr is offline   Reply With Quote
Old 05-23-2012, 12:37 AM   #1602
Question Re: GT3B Hack Question and Answer Thread
Is it possible, with the 6 channel rx, to turn the 3rd channel trim button for rear steer, to so when i push button it turns right, pull button turns left and make the D/R run a winch (when i push forward winch out, pull back it pulls.) then the 3 channel button be a 3 position for a dig. If so, im buying your kit.
MiniMorris is offline   Reply With Quote
Old 05-23-2012, 03:05 AM   #1603
Got Worms?
100% correct
losikid is offline   Reply With Quote
Old 05-23-2012, 05:14 PM   #1604
My wheel showed up today. It didn't take much to shim the adapter. I just snipped off a piece with scissors from an old ID card.
I may pick up a different wheel for my other GT3B
spoo76 is offline   Reply With Quote
Old 05-26-2012, 02:04 AM   #1605
Cant get the firmware archive to open or email to work on Overkill rc.. Anyone got the newest firmware?? Or a way that I can download it? Thanks..
Old 05-26-2012, 09:19 AM   #1606
Got Worms?
Click on this link...its on my website too, but I can't access my control panel on my phone
http://rc.305.cz/download.php?soubor=25
Old 05-26-2012, 12:12 PM   #1607
Thanks!! Now with the 6.0 do I still have to reflash for 3 - 6 - or 8 channel or is it all included in the one firmware?? Appreciate the help again!
Old 05-26-2012, 01:49 PM   #1608
Exclamation Re: GT3B Hack Question and Answer Thread
Oh No! when will they be back in stock??
Old 05-27-2012, 08:43 PM   #1609
Ok i am having a problem with the drag break.
My set up is two micro sidewinders, bec set to 7.0 using 3s lipo gt3B just reprogrammed it twice.
The problem is when i go to use dig my drag break is lost but if i dont have it in dig the drag is perfectly fine. The drag is set to 213% and 100% braking.
It feels like the drag stays on for about a second then turns off which makes dig kinda less affective.
If anyone knows how to help let me know. Thanks.
foratm is offline   Reply With Quote
Old 05-28-2012, 07:22 PM   #1610
Speaking of dig, just put a dig unit on my wraith. Can onyone point me to how to program the gt3b for it? Running 0.4.1.
stricker76 is offline   Reply With Quote
Old 05-28-2012, 07:27 PM   #1611
you will have to read a bit to find it but This is the manual for that version
http://www.overkillrc.com/GT3B-Firmw...NUAL-0.4.1.txt
Old 05-28-2012, 07:27 PM   #1612
Got Worms?
calibrate your esc's....if that don't work open up your deadband
Old 05-28-2012, 07:28 PM   #1613
Got Worms?
i'm not familiar with the wraith dig unit, is it 3 position? what position does what?
Old 05-28-2012, 07:33 PM   #1614
Yup, 3 position. Right is normal, centered is freewheel, left is locked.
Old 05-28-2012, 07:40 PM   #1615
Got Worms?
Do you want those same positions on the radio, or do you prefer that the normal is in the center?
Old 05-28-2012, 07:52 PM   #1616
Would prefer normal center.
Old 05-28-2012, 08:18 PM   #1617
Got Worms?
Ok so,
Scroll to E. Point,
Press and hold enter for 1-2 seconds (LONG enter)
scroll to P, press enter
scroll to CH3, press enter
scroll to 0, press enter
scroll to -100, press enter
scroll to 100, press END
Now press back afew times
Scroll to REV, LONG enter
scroll to 3, enter
scroll to MPO, press enter
scroll to NOL, LONG enter
Now the CH3 trim switch should change your positions, make sure to set CH3 endpoints
Old 05-28-2012, 10:23 PM   #1618
Got it. Thanks again!
Old 05-28-2012, 10:58 PM   #1619
Got Worms?
Here's the files for 0.6.1
Firmware (its 2-8ch...model depedent)
http://www.overkillrc.com/GT3B-Firmw...gt3b-0.6.1.s19
and the manualm(0.6.1 is way different then 0.4.1 ... please read manual before updating)
http://www.overkillrc.com/GT3B-Firmw...NUAL-0.6.1.txt
Old 05-29-2012, 09:38 AM   #1620
Hey Austin,
Have you tried installing a pot on CH3?
This is copied from the new firmware manual:
- enter it by wheel right-turn and ENTER-long
- 6 menu items starts to blink (+ 2 arrows if CH3 is potentiometer)
- use END or ROTATE to change channels
- there is also channel 3 representing CH3 button (for those who will do
some 3-position switch/potentiometer modification)
> There is 1K resistor connected between CH3 button and +5V, so
simply connecting linear potentiometer instead of CH3 button
will not work. Usefull results can be done with logarithmic
potentiometer 10K which has 1K at half of turn. Or eliminate
internal resistor to +5V, connect potentiometer between +5V
and GND and potentiometer output instead of CH3 button.
Were you able to get it to work, and maybe it was in the manual or is obvious, but I have missed it... do you still get to adjust trim and end points on CH3 when you do this?
Al
heyok is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
