07-03-2012, 03:58 PM | #1721 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Your stings arn't quite right (if you want me to, just tell me what you want and i'll type up the settings...but its better to figure it out yourself as you will understand it better) The best way todo this is to look at the manual and follow along while you program. So you go into the long click REV menu (key mapping menu) You'll see that REV is blinking and a single digit is blinking on the left. This digit is the switch you need to select. 1,2,3 is trim switches. d is the d/r switch, c is the ch3 button, e is the end button...So choose your switch. Now choose the function(thing you want to control). Pretty much any setting can be assigned to a switch. In your case you want channel 3, so you'll choose CH3 After pressing enter you see the % sign light up, this is to select the "buttons"(how they act), there is a list in the menu. After pressing enter you see just a V and no percent. So looking at the manual, you see that it skipped the step rate (V % signal) step and you're on the reverse step (reverse the switch) I know all the acronyms and menu sequence by heart as i write steps out everyday, but the manual is a great resource when navigating the menu's. | |
07-03-2012, 04:32 PM | #1722 |
Newbie Join Date: Jul 2012 Location: Brighton
Thanks I 'think' I have it. I have everything working the way I want it. Now to mess around with it more to get more experience. Thanks again for the help !!!! |
07-03-2012, 07:19 PM | #1723 | |
Newbie Join Date: Jun 2012 Location: New Zealand
For those interested I have managed to resolve this. I install Oracle VM VirtualBox 4.1 and installed Windowz XP inside it as a VM. I had some initial issues getting USB to work, but reading the documentation does wonders. Now I can enjoy the fruits of losikids labours from the comfort of my Debian machine. Thanks heaps losikid for your fantastic work. Regards Fred | |
07-03-2012, 11:57 PM | #1724 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Thanks for the help. A little time,reading and tinkering helped me figure programming out. Got channel 3 set up with both a momentary and a rpt setting on different buttons. Now to finish my servo winch. Is there a way to make the step range go past 100/-100? Or is that the limit? Just asking because when I use a non-converted servo its 100% is the 45* or whatever range it is from center. If I'm making this into a servo winch it needs to go as long as I hold the button. Sent from my PC36100 using Tapatalk 2 Last edited by Shinjari; 07-04-2012 at 12:00 AM. |
07-04-2012, 10:00 AM | #1725 |
If you convert the servo to do 360* it will turn at 1% all the way to 100% it will just turn faster the higher the step % it will only stop when you go back to 0%. It will not only go to 45* or whatever it would do unmodified since the potentiometer isn't turning like it would when used as a normal servo Sent from my iPad using Tapatalk |
07-04-2012, 10:39 AM | #1726 | |
07-04-2012, 07:15 PM | #1727 |
Here's the firmware archive link Index of /GT3B/GT3B-Firmware to get to other gt3b related files go to here Index of /GT3B This bypasses the website... |
07-04-2012, 10:36 PM | #1728 |
Anyone who has ordered a hack kit from me...did you just get a new email with new downloadable content (0.6.1 fw)? I think when i update the files to a product its supposed to email all previous orders with that product.
07-05-2012, 08:49 AM | #1729 |
| Re: GT3B Hack Question and Answer Thread |
07-09-2012, 10:22 AM | #1730 |
I did not as well.
07-09-2012, 10:55 AM | #1731 |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
WOW! I can't belive I read this thread from #1 to here. I think it's time for a beer.
07-09-2012, 11:55 AM | #1732 |
07-09-2012, 06:25 PM | #1733 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
07-09-2012, 07:32 PM | #1734 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
07-09-2012, 10:14 PM | #1735 |
07-10-2012, 07:58 AM | #1736 |
Newbie Join Date: Jun 2012 Location: Greece
Hello. I'm planning to order a GT3B-Pre Hacked with 8ch firmware, and would like to know two things (sorry if my question has already been answered): -Can I program the transmitter including trims, epas ... from my computer, or can I just program switches and their functions? -Is it possible to add additional switches to the transmitter, without having to modify the firmware? Thanks in advance. |
07-10-2012, 12:07 PM | #1737 |
I have a 4 wheel steering question I'm wondering about. Right now I run the 3 channel firmware but wanted to go with the 6 channel firmware and try the following: Put a servo on channel 1 and 3. ESC on channel 2 (like regular). Channel 1 - front steering Channel 3 - rear steering In one mode I'd like the rear to have a dual rate and expo different than the front. So, the rear could have 75% expo and the front 0%. This would give you very little rear steer in normal cases, but when you cranked the wheel all the way, you'd get full rear steering. Can we do this with the programming? I'd do this in my Wraith, then regular dual ESC in my XR10 (with the same radio, different model in the radio) |
07-10-2012, 03:39 PM | #1738 | ||
All the settings are programmed on the radio And no, you can't add additional switches Quote:
But yea it should work, you can also assign expo to a switch so you can adjust it on the fly | ||
07-10-2012, 05:29 PM | #1739 |
At first I was thinking I was going to need 2 escs but was thinking about an XR10 with dual steering. I'll have to find the instructions again and see what the settings would be. 3 channels will work because you're not allowed rear steer on XR ad wraith only needs one ESC. |
07-10-2012, 07:55 PM | #1740 |
Pebble Pounder Join Date: Mar 2010 Location: Orlando
Hey Losikid, I have your gt3c with all the goodies. I am trying to run a Savox SB-2270SG and I think I mibe having issues do to resolution. I know that you had this same problem with your gt3b and this servo. I would have just asked there but that thread has been dead for awhile and I kinda figured you check this thread regularly, did you ever find a solution. or what the problem actually was?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
