![]() | #1881 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
![]() | #1882 |
Newbie Join Date: Oct 2010 Location: Warsaw
Losikid, I read and figured the only real con is the power button in the steering wheel and some were saying turning all the way to the right I believe it may cut in and out of power.
![]() | #1883 | |
| ![]() Quote:
But yes, that is the only con i can think of. However, i think its an easy fix | |
![]() | #1884 |
So personally you would go with the GT3C?
![]() | #1885 |
Yes, thats what i'm running and i'll never run a gt3b again...the gt3b is proven however, and abit cheaper so i can see why people would prefer it.
![]() | #1886 | |
| ![]() Quote:
Does the newest firmware in the GT3B close the gap a bit between the "B" & "C"? I can't really fault the GT3B, especially for the price. ![]() Calvin (asw27x) could like the GT3C, it's go well well with his orange XR-10..... 2012 season rig "The Orange" PS, are you going to support the GT3C in this thread, or start a new one? ![]() ![]() Last edited by Charlie-III; 08-12-2012 at 12:13 PM. | |
![]() | #1887 |
weight, ergo, feels like a better radio. Build quality also seems higher The speed is the same as the gt3b, the firmware is the same as the gt3b, switch layout is very similar to the gt3b, screen has the same layout (different color though). So far gt3c has just stayed in this thread. It may change, but this thread is mostly firmware questions, so i think they can stay together |
![]() | #1888 |
The new frsky gear will increase speed by 11ms
![]() | #1889 | |
| ![]() Quote:
![]() | #1890 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Im curious.Any pictures of the micro frysky RX next to a flysky? The only advantage for me might be the micro RX for my micro RC's. Much needed but possibly not worth the cost for just that.
![]() | #1891 | |
| ![]() Quote:
![]() | #1892 |
wow, might have to retract my previous statement. that thing looks smaller than just the decased GT3 RX board.
![]() | #1893 |
Yea its tiny...I'll be running them once i get a new version of the gt3c...my proto type has the built in 2.4 module, so i can't just remove it ![]() |
![]() | #1894 |
| ![]() they are easily removable in the C? or is it like the B. I believe Ive seen the C tear down pictures but Its been a while
![]() | #1895 |
No its just as hard. Not something easy todo.
![]() | #1896 |
Rock Stacker Join Date: Feb 2012 Location: Massachusetts
How can I disable the low voltage alarm with out the hack stuff? Are there any wires I can just cut in the transmitter? ![]() |
![]() | #1897 |
Newbie Join Date: Aug 2012 Location: fort campbell
Hey losikid, i got your message about the 6ch rx being out of stock. Can you recommend a good place to get one and perhaps what rx works with the gt3c. thanks |
![]() | #1898 |
well i thought i would finally get to hack my radio after i purchased your kit and thought i have gotten a dud the first time i bought the programming board ![]() Reading PROGRAM MEMORY area... Error : Cannot communicate with the board. Wrong board selection or check board power supply or check that a previous session is closed. Error : < PROGRAM MEMORY reading failed. help please |
![]() | #1899 |
| ![]() you can turn it off in the global settings menu. instructions on the overkillRC site
![]() | #1900 |
| ![]() Turnigy,Flysky,hobbyking, & Eurgle will work as well as the newer 2,4ghz 3ch from axial. there is another big name manufacturer that started using the cheaper hobby king TX & RX but i cant recall who.. RX's can be found on hobbyking,hobbypartz,ebay or just Google it
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
