Thread: GT3B Hack Question and Answer Thread
Old 08-29-2012, 05:03 PM   #1941
Got Worms?
Default Re: GT3B Hack Question and Answer Thread
Originally Posted by cartronicshn View Post
so my gt3b with 4.2 and the one on 6.1 should be around 10ms
No, after some tests on the o-scope it was discovered that the 4.1 averaged about 40ms latency...so it was optimized and got it down to like a 25ms average...and afew more tweaks were made between 4.2 and 6.1 to drop another ms or two
losikid is offline   Reply With Quote
Old 08-29-2012, 05:22 PM   #1942
cartronicshn's Avatar
so about as fast as stock? which was 20ms right?
cartronicshn is offline   Reply With Quote
Old 08-29-2012, 05:41 PM   #1943
Got Worms?
I haven't seen any tests on sock adios....but i'd assume slightly faster as i doubt the flysky engineers would have made a firmware that is extremely efficient in getting info to the module as soon as possible. Right now, the latency can't get any faster because the module is a 20ms module. With the new frsky 11ish ms is possible on the latency
Old 08-29-2012, 05:56 PM   #1944
Originally Posted by LosiKid View Post
I haven't seen any tests on sock adios....but I'd assume slightly faster as I doubt the FlySky engineers would have made a firmware that is extremely efficient in getting info to the module as soon as possible. Right now, the latency can't get any faster because the module is a 20ms module. With the new frsky 11ish ms is possible on the latency
OK (turn on sarcasm....) what is "sock adios"?? Are you going barefoot?? (yes, I know you meant "stock radios"). Frikkin "auto spell check....."
For crawling, I really don't see latency as an issue. On a "go fast" I can a potential issue.
I have yet to upgrade my firmware, so I can't comment yet.
Charlie-III is offline   Reply With Quote
Old 08-29-2012, 06:06 PM   #1945
Got Worms?
Auto correct
I guess i should proof read more often
Old 08-29-2012, 08:50 PM   #1946
Auto correct
I guess I should proof read more often
No problem with me......just saying.
Thanks for all the help in this thread. Quite a few of us trying to help fill in the gaps.
"Smooth sailing on the move".....
Old 08-31-2012, 03:36 PM   #1947
humm..... i´ve been reading a lot of pages but (maybi missed it) i've only found someone with se same issue i have, and no resolution ....
i have the 2 esc template setup, but the dig dont stop the motors ... ch3. to the left and back wheels turn slowly ch3. to the rigth and front weels turn slowly
if i throtle up both motors turn foward ....
any one to help me ? thanks.
zmaxroad is offline   Reply With Quote
Old 08-31-2012, 04:04 PM   #1948
Got Worms?
Calibrate the radio, calibrate your esc's
Old 08-31-2012, 05:04 PM   #1949
have done esc / radio calibration several times ... always the same result ... instead of "full locked axle dig" i have a "slow speed axle dig" :(
Old 08-31-2012, 05:11 PM   #1950
Originally Posted by zmaxroad View Post
have done ESC / radio calibration several times ... always the same result ... instead of "full locked axle dig" I have a "slow speed axle dig" :(
Hmmm....I have a hacked GT3B, dual Sidewinder Micros and used the supplied template with no issues.
I did change the "20" for proportional steps to "5" since it made more sense to me.
When you calibrated the ESC's, were the EPA's set to 100% and the trims (and possibly subtrims) were set to "0"??
What version GT3B software are you running? I'm running an older one.
Old 08-31-2012, 05:22 PM   #1951
Got Worms?
This issue is caused by a uncalibrated radio. So calibrate the radio again, especially the throttle channel.
There is a calibration how-to in post #2 of this thread
Old 09-01-2012, 12:50 AM   #1952
Got Worms?
Spent some time tonight on these....still have quite abit more todo. Once finished they'll turn into a small 3x5 booklet
http://www.overkillrc.com/GT3X-Firmw...lp%20cards.pdf
Old 09-01-2012, 09:14 AM   #1953
Austin, thanks for all the support you provide for these radios.
Old 09-01-2012, 01:03 PM   #1954
Got my GT3C finally, turned it on to make sure it worked. installed hack kit, soldering with off without a hitch. put it back together. Now it won't turn on. rechecked to make sure all the wires were tight. still nothing. do you think i fried the controller?
I charged it too, still nothing. thinking i should have just tried my luck with getting one from losikid.
mudboggin3 is offline   Reply With Quote
Old 09-01-2012, 01:07 PM   #1955
Does the new firmware allow a "return to previous" when "dig" is locked?? I like on the "mom" dig that I go back to 5% propo when I return to 4WD. In "locked dig" it's not an option.
+1.
I would double check you didn't bridge a pin on the hack header, then make sure the connection from the wheel (& power button) are good.
Is your wheel connection (to the main TX body) wires or the spring pins?
Old 09-01-2012, 01:23 PM   #1956
my is wires, no pins. the solder joints look good, no bridging from what i can see. maybe i should desolder it make sure.
Old 09-01-2012, 01:42 PM   #1957
Okay took the 90 degree header out, broke it in the process though. now the radio turns on. so new question, anyone know where i can buy a new header for it.
Old 09-01-2012, 02:00 PM   #1958
Either LosiKid/OverkillRC or Digikey.
Old 09-01-2012, 02:15 PM   #1959
Got Worms?
Yea, i'll explain the rest of the menu key mapping menu options on another card/page.
Old 09-01-2012, 02:16 PM   #1960
Got Worms?
Your issue is strange...
I'll send you a new gt3c header next week, send me an email sometime after monday...make sure and send the email to losikid@overkillrc.com
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
