06-18-2011, 09:58 AM | #1 |
Rock Stacker Join Date: Apr 2011 Location: UK
| BEC help
I have just purchased the DX3C and the SR300 that came with it. I was wondering what channel i can stick my bec into on the receiver? Can it go in the bind port and Aux port? Thank you |
06-18-2011, 10:20 AM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
06-18-2011, 10:43 AM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
it goes in the aux channel. but if your using that channel then your next best bet is to hardwire it directly to your servo.
06-18-2011, 11:37 AM | #4 |
it can go in the bind port but its a good idea to pull the orange wire from the plug so there isnt any chance if it going into bind mode, since that port is also for a rx pack for a nitro vehicle
06-19-2011, 12:58 PM | #5 |
So should i just keep it in the aux port
06-19-2011, 03:39 PM | #6 |
06-20-2011, 02:22 AM | #7 |
06-20-2011, 02:24 AM | #8 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Yes, the bind port is fine. I run SR300s in nearly all my rigs with the BEC plugged into bind. You will be fine. Casey |
04-29-2014, 10:05 PM | #9 |
Newbie Join Date: Jan 2009 Location: Milford
| Re: BEC help
why does my receiver sr300 cut out on the throttle end w/ ccbec installed, but not with a 5cell 6v hump pack plugged into to same port (bind)???
05-01-2014, 11:47 AM | #10 |
Quarry Creeper Join Date: Jan 2012 Location: My house
I have mine plugged in the bind port because I'm using the Aux port for my winch the bind works good... Just make sure you are bound to the receiver because it will confuse it thinking its in a bind mode and not power up... Then you should be good it's worked for me since
