06-22-2011, 08:39 PM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: Hong Kong
| Dual FXR Lipo NEWB question
Hi, I have dual FXRs with 45turn motors on my Bully and I've been out of the game for an year or so and forgot what little knowledge I had about these batteries... I recall a kind member telling me that 2200mah 3cell lipo with a 35C constant amp rating will do the trick but I just relocated to Korea (from HK) and dont seem to be able to find this exact spec... My question here is... as long as its 3C is it okay if the MaH exceeds 2200? Also, does the 35C constant amp rating matter? Can I exceed the 35C without killing my escs? Any advice would be greatly appreciated! Mike |
06-22-2011, 08:50 PM | #2 |
This one looks like it might work but... once again, really unsure 2000mAh 11.1V(3S1P) 30C Lithium Polymer Battery. Continuous discharge : 30C Burst discharge : 50C Nominal Voltage : 11.1V(3.7V * 3) Capacity (mAh) : 1200mA Temperature : Charge 0 ~ +45℃, Discahrge -20 ~ +60℃ Charge rate : 1C Dimension (mm) : 25mm x 37mm x 107mm Weight : 180g |
06-22-2011, 09:08 PM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: United States
The battery can be as many mah as you would like however 2200 is already double the size most people run. It will hurt your performance because of the weight and placement. It is fine though. Also you can up the c rating to whatever you wont, no harm. Basically as long as you have 11.1(3s) volts and 25+C rating. I would recommend something more like this. http://www.cheapbatterypacks.com/pro...Lipo-Pack.aspx |
06-22-2011, 09:48 PM | #4 |
Hi PowerCrazy, Thank you so much for your kind response! I'm running out to the hobby shop now on your kind advice... once again, thank you very much! Cheers, Mike |
06-23-2011, 06:24 AM | #5 |
Most of us using the Bully are using 800 to 850 mah 3 cell packs. They provide more than enough power for a 6 to 8 minute comp, are small and light. The ones I have can be charged at 2C and HK's Nano-Tech can be charged at 5C (so they claim). |
