02-21-2013, 11:13 AM | #121 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
| Re: Wire Gauge and plug Size
Thanks for the input. So I'll go with 16g. I already have some at home since this is what I was going to use. The battery plugs I use are the XT60 (because they came standard with the turnigy) and are only 1 or 2gr heavier than the deans. I can live with 2 more gr, because I'm cheap! |
02-27-2013, 11:50 AM | #122 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
FXR is in the mail. It says it comes with 12ga wire. Should I not use that and go with 14ga?
02-27-2013, 03:39 PM | #123 | |
| Re: Wire Gage and plug Size Quote:
Slight weight penalty Slightly more weight Less flexible There is nothing wrong with a heavier gage wire. It will help performance under max load, but in a crawler may not show the difference. Wire sizing is based on: Expected amp load Length of wire If you have a high amp load and/or long wire runs, you need to up the wire size (smaller wire gage #). | |
01-13-2018, 02:16 PM | #124 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
Good 16ga wire is like a wet noodle.
