Deans plugs wont go plug up? Im making the switch to deans plugs, and when I soldered the plugs to the esc, and battery they will not plug in together. I finally got them to go a little bit and they were a mother to get half way together and pull them back out? Is there something im doing wrong or is there a technique? "thumbsup" |
did you get any flux down in the deans connection. |
You may have applied heat too long and mis-shaped the plastic. |
I have found if you don't plug the female and the male ends of the plug together when you are soldering the wires on them the heat can warp the prongs just enough that they won't go together. Hope this helps. |
Yeah I scraped some of the flux off and it went in. Thanks guys. |
flux hardens after being heated. they knew what they meant. |
The best way to prevent this from happening is to not solder the Deans vertically. I use a set of "helping hands" that holds the plugs on their side, the flux runs to the bottom of the solder joint and is easily cleaned off with some isopropyl alcohol. |
I got some cheap brand and they didn't work with the real deans either. :twisted: |
A guy at a LHS tried selling me some of those. They looked like Deans, but the packaging looked real cheap (white cardboard) and the plugs were bright red. He said, "They are just like Deans, but cheaper..." I told him that I could not see the sense in buying a knock-off brand for something I'm going to put amps of power through, when that cheap knock-off fails and my rig goes up in flames will it still be worth the buck I saved? |
It's mostly the plastic deforming from holding the heat too long on the terminals when soldering. More commonly seen when using guns or weak irons. Best way is to plug the male into the female and then solder the wires on. that way each end holds the position and doesn't deform/melt. |
I got them on line and where advertised as dean's but as soon as I saw them I knew I was screwed. I only use them on the mini, I would never rely on them in the 2.2 comp truck. "thumbsup" |
