07-03-2011, 05:52 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Franklin, Va
| revolver questions
Hello all! I have a Revolver 1050kv ( I think), and put it in my 2.2 scaler. I am running a 87t axial spur with slipper. What pinion should I consider? Also, I am running a sidewinder V2 with it. I'd really like some wheelspeed.... |
07-03-2011, 06:36 PM | #2 |
Quarry Creeper Join Date: Apr 2011 Location: United States
If you want some wheel speed I would suggest volting up. that 1050 means 1050 rpms per volt so its a slow turning motor. More volts = more rpms. You can then gear it up based on the temp of the motor. Maybe try a 16 and run it and see if it gets hot or not.
