07-04-2011, 10:50 AM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: Farmington
| 3R racing winch handle 3cell lipo?
Any of you guys run your 1/10 scale 3R racing winch off your 3 cell lipo? If not did you just wire in a 10amp castle bec to power it? thanks.
07-04-2011, 11:03 AM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
mine is running thru ccbec at 9v. never bumped it past 9v as I heard it doesn't last long past 9
07-04-2011, 11:15 AM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
Used for quite awhile on 3cells,no problems. Went back to c.c. Bec at 7v just to be safe. Just alot slower and less power now.
07-04-2011, 11:20 AM | #4 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
BEC set at 6 volts for lights and winch
07-04-2011, 11:24 AM | #5 |
Rock Crawler Join Date: May 2009 Location: 354
07-04-2011, 12:00 PM | #6 |
Think it would kill a bec to run a steering servo and winch on the same bec set at 6 volts? I could see being in a bind and having to steer while you winch your way out.
07-04-2011, 12:25 PM | #7 |
| That is how I currently run mine, and I've had no problems so far. I'd like to run a dedicated BEC for the winch so I can up the voltage, but I have a different plan for that down the road.
07-04-2011, 12:38 PM | #8 |
How exactly do you wire a BEC dedicated to powering a winch? The winch controller has it's own power input so do you take the BEC plug that would normally go to the rx and wire it to winch controller input? Right now I'm running a seperate 7.2v battery for the winch and it's a PITA.
07-04-2011, 12:47 PM | #9 | |
Thats what I'm going to do. | |
07-04-2011, 02:09 PM | #10 | |
DOOH!!! Join Date: Feb 2007 Location: AZ
07-09-2011, 12:42 PM | #11 |
So my next question is..... Can you tie the power leads of the winch into the leads that go to the reciever for the winch? If I use a bec to power my reciever anyway might as well just pull power from it right? |
07-09-2011, 05:39 PM | #12 |
| You could but your only going to be feeding it what the BEC is set at and I'm not sure you want to pump 7+ v into your receiver then remaining electronics just to make the winch happy. If you run the BEC at 5v then the winch will be slow and weak.
07-10-2011, 07:21 AM | #13 |
| Spectrum recievers can handle up to 9.6 volts and my hitec servo is good to 7.4 volts. So if I set my bec for 7.4 volts everything should be happy right? I just wonder about the amp draw from the winch thru such small wiring on the reciever leads, but the power leads on the bec are the same size so guess it's not a big deal.
07-10-2011, 08:34 AM | #14 | |
07-10-2011, 09:24 PM | #15 |
07-13-2011, 08:14 PM | #16 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
I currently run my 3racing winch on 3cell using a cheap esc off ebay. The ESC is a rated to 7.2v and has been encased in plasti-dip for waterproofing. On 3cell it runs perfectly fine, and will pull about 11kg before stall (if the gearbox will hold) Every time, the gearbox is the thing that breaks not the motor, and I have even run one recently on 4cell for a short while, but after spooling in too quick and hitting the fairlead, the gearbox exploded |
07-13-2011, 08:21 PM | #17 |
