07-13-2011, 12:05 AM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Oshawa, Ontario Canada
| Novak M2 Dig Problem????
I have the Novak M2 Dig ESC and two Novak Black 55 turn brushed motors in my XR-10. I bought the truck last fall took a month and a bit to build it as I was buying things along the way. Last week I set up the ESC with the One Touch. First try every thing worked, set up the dig on channel C on my Specktrum DX3R as just front full power or rear full power. I took the truck out to test it all went well till I lost a screw from the steering. When I got home fixed up the steering and re-arranged the ESC and reciever, so I had to un solder the motor wires and re-solder them I touched nothing else.... Now I turn on the truck the steering works butt nothing else, I checked the reciever it's fine any IDEA WHAT I COULD HAVE DONE TO IT??????? PLEASE HELP!!!!!!!! |
07-13-2011, 01:13 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Earth
An obvious suggestion, but have you tried re-calibrating the receiver to the controller? Also, did you wire anything the wrong way round. I lost my first ESC because I missed the fact that I had soldered my power wires on backwards and fried it, plus 2 brand new batteries. Never made this mistake until then, and everyone knows not to do it. But it happens. |
07-13-2011, 06:05 AM | #3 |
Did you flip the ESC to RX wire? Dark wire (black or brown) usually goes to the outside edge of the RX. Does the ESC light up? |
07-13-2011, 06:15 AM | #4 |
Check your motor wires, you may have soldered a front and rear one on the front motor, that would explain the RX getting power but no go.
07-13-2011, 08:04 AM | #5 |
The reciever wires are right black to the outside, the motor wires arethe same as when it worked red wire to + black wire to - and the red wire to - and black wire to + on the rear. When I use the One Touch set up all the lights on the ESC light up as they should all the way to step 8, I think in the 3rd channel set up things are going wrong.
07-13-2011, 11:11 AM | #6 |
Solved the problem, found out the AUX Channel some how is not working on my DX3R there for I could not finish the One Touch progaming, switched radios to one of my DX3E and it works again.
07-13-2011, 03:21 PM | #7 |
