07-13-2011, 06:05 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: powhatan
| 19.2v craftsman drill motors
thinking of an moa conversion for my losi any thoughts on these massive motors for crawling. i know the torque wouldnt let me down but have no idea about the wheel speed
07-13-2011, 06:17 PM | #2 |
here's a pic of the drill motor next to the stock losi 55t motor |
07-13-2011, 06:18 PM | #3 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
If they aren't 540 size then they aren't going to bolt up. And are they rebuildable? Probably not. If you are going to buy a conversion then you need some serious power for the losi. Like two brushless or pullers
07-13-2011, 06:26 PM | #4 |
they are way way bigger than 540 and i dont think power would be an issue just not sure if the weight would be an issue here are the specs on the motor Mabuchi Performance Model RS-775WC-8514 Operating v : 6v - 20v Nominal v : 18v No Load RPM : 19500 No Load A : 2.7A Stall Torque : 1216 mN-m Stall Current : 130A RPM - Peak Eff : 17040 Torque - Peak Eff : 153 mN-m Current - Peak Eff : 18.7A Last edited by thundaar; 07-13-2011 at 06:30 PM. |
07-13-2011, 11:26 PM | #5 |
Quarry Creeper Join Date: May 2011 Location: Salt Lake City
not an electric motor guru at all in anyway.... But if you can mount them and provide the needed juice.... i honestly do NOT see any issues with them running losi worms. Power? have you had an electric drill in your hand when it bites?? Torque? plenty.... its a drill for god sake.... weight? i see that taking the only drawback next to size itself. If i had the resources and the spare time to mount them.... i do it too Go for it! P.S. this may come to post a bit later.... but i know there are a few guru's when it comes to electric motors on here. Id ask Brood and Holmes about the power these motors need to make the numbers you have listed. maybe even butcher the speedo out of the drill some how. i don no |
07-13-2011, 11:30 PM | #6 |
Rock Stacker Join Date: Mar 2011 Location: california,Modesto
One word ****! dude even if they say dont do it i say DO IT!!! i wana see this happen haha |
07-14-2011, 05:47 AM | #7 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
I dont have any experience w/ the 19v but I am running a Mabuchi motor from a 15.6v drill in my super heavy scaler and its smooth like butter and gobs of torque. it was a PITA to get the pinion gear that the motor came with off but once that was done and a flat spot ground onto the motor shaft its been all good since then! and I'm waiting on a 14.4v DeWalt for my Summit as well
07-14-2011, 07:03 AM | #8 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
People have used them before....last time I tried to talk someone out of using a motor not meant for the application, it didn't end so well... I will say this, the Losi is very hard on motors. Rebuilds are pretty common on brushed motors in them, can you rebuild these? So, by all means have fun......never hurts to try I guess. Later EddieO |
