![]() | #21 |
Newbie Join Date: Dec 2015 Location: Braga
Hello guys, I know this topic has years, but I use one of this BECs in my boat, and as I'm coating the receiver with MG-422B silicone, I want to know if anyone ever removed the factory blue heatshrink, if it's safe to remove it, and if I can't coat any part of it. I think it's a cleaner way of doing the work removing the blue heatshrink and use this silicone coating instead of using normal silicon on both holes, and or using balloons, but I need to know it's safe to remove it, I know that I will void the warranty, but as this is for work in close with water, sooner or later water will come in, so I think the risk might be worth it. Hope anyone can help. Thanks in advance! |
![]() | #22 |
Moderator ![]() Join Date: Jan 2004 Location: chicago
yeah you can remove the blue shrinkwrap.
![]() | #23 |
Quarry Creeper Join Date: Nov 2013 Location: lethbridge,alberta, its mighty windy here!!
i removed the heatshrink off mine and gave it several coats of mg's sillicon coating, no problems at all. only thing to take into concern is that technically ( i assume ) it will void any warranty should the bec die and you want to consider sending it in for repair if thats an option for the bec with castle. from observation when i did mine it did already look like the pcb and components already had a coating on them but putting some more on helps, no issues using mine in snow and winter slush once it was done, the same for my mmp when i did that too. tony |
![]() | #24 |
Quarry Creeper ![]() Join Date: Jan 2017 Location: Olathe
Home waterproofing will void the warranty, but if it goes wrong or you don't have one yet, we do sell a newer version that is more powerful, waterproof, and has an aluminum case.
![]() | #25 |
Thanks guys for helping and so fast, earlier today morning I removed the heatshrink and applied the first coating on the top PCB ( both sides ) of the photo. Should I also do the coating in the bottom PCB of the photo? ![]() Thanks. Last edited by Morcegolas; 05-04-2017 at 06:41 AM. |
![]() | #26 |
Moderator ![]() Join Date: Sep 2008 Location: PA
For those using conformal coating, are you using silicone or urethane?
![]() | #27 |
I'm using silicone, MG Chemicals 422B ;)
![]() | #28 | |
| ![]() Quote:
Yep, if their are components on there cover them too. The tinned board attached to the inductor and capacitor is I assume to help with some thermal dissipation as I noticed mine was held on with some double sided sticky pad, presumably again a thermal bandage/tape so it does need some gentle coaxing to get loose but just make sure to give everything a good few coats with some drying time in between and it will turn out great. Tony | |
![]() | #29 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
I'm curious what those three holes are for just about midpoint on the PCB. I'm just going to squirt some ShoeGoo in each end of mine, have it double-sided taped in and don't feel like removing. Not looking for 100% waterproof, just 100% peace of mind about minor water incursions. |
