07-18-2011, 11:59 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Spiffy XR10 Electronics shrinkage
Here is another build thread for you folks to see my work. This is to promote my custom electronics soldering/wiring side gig in the link below. Today, I did a full wire job on a buddies XR10. Gave the Mamba Micro Pro ESC's what I call a "Super Smash". Turned out pretty decent. Let me know what you folks think. The pics aren't the greatest. So sorry about that. Custom Soldering/wiring As I got it Electronics yarded Once I de soldered everything, I bent the cap on one of the ESC's, to accommodate for the heat sinks to mesh into each other. Then I soldered a jump lead to the power terminals. After some measuring, I cut and tinned all the wires, and soldered em on. Then I shrink wrapped them together. BEC attached, then test fitted to the skid. This is something I think is kind of neat. A way to shorten the servo lead, without breaking into the case, and hopefully not voiding any warranties. I cut the wire to where it needed to be. Pulled the pins, and then soldered directly to the pins. Then re-installed the pins to the housing. Worked out kinda slick. Then, everything was neatly installed, motor leads soldered on, and zip tied up! I used 3mm bullets, and nice American made 18awg wire. The 3mm bullets are almost the same diameter as the wire, so it looks real clean. |
07-19-2011, 12:09 AM | #2 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Nice job Chris. That setup looks super sweet. Do you need the cap on both esc? I see some people only running 1
07-19-2011, 12:19 AM | #3 |
Newbie Join Date: May 2010 Location: Portland Oregon
Man that is some clean work cant wait to c it in person. My berg will b heading ur way very soon...
07-19-2011, 05:13 AM | #4 |
Pebble Pounder Join Date: Jul 2009 Location: Woodburn
nice work Chris! Just wait until I get back, my crawler is getting completely rebuilt!
07-19-2011, 05:27 AM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
For shortening servo leads I purchased this kit from Hansen Hobbies. It comes with a stripper, crimper and servo connectors. http://www.hansenhobbies.com/product...orkits/ck_sck/ |
07-19-2011, 11:02 AM | #6 |
07-19-2011, 12:20 PM | #7 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
That's just plain crazy, nice work man. I'm curious though, do you anticipate any heat issues with the sinks crammed together like that? |
07-19-2011, 12:33 PM | #8 |
I suppose it all really depends on how you drive it. But all in all, there is not a lot of air flow in the chassis of a crawler anyhow, seens how they dont go fast enough to get more than a light breeze at best. So I would guess it will make next to no difference
07-19-2011, 12:36 PM | #9 |
| That's a good point... Hope you don't mind that I'll probably be stealing a couple of your wiring ideas when I finally get around to rewiring my junk |
07-19-2011, 01:17 PM | #10 |
Is the BEC wired directly to the servo via a Y harness? The "super smash" look good, Where do you find shirnk wrap big enough to fit over the esc's? The biggest I've seen are for the ni-mh stick packs. |
07-19-2011, 01:47 PM | #11 | ||
http://www.rccrawler.com/forum/showt...27#post3193127 I have a wall with shrink wrap from 29mm all the way up to 138mm here at work. The shrink I used for them was 48mm for the ESC's, then 56mm when I shrink wrapped the BEC on. | ||
07-19-2011, 01:56 PM | #12 |
Rock Crawler Join Date: Jun 2008 Location: Grants Pass OREGON!
Nice chris!! superb work and craftsmanship. Think this can be done with a pair of fxrs? |
07-19-2011, 02:00 PM | #13 | |
Tekin FXR Shrink Thread | |
07-19-2011, 04:25 PM | #14 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
Dang it you beat me to it. After seeing your fxr's I had this in mind for my micros. Curious about the power leads on the bec are they soldered to the back of the esc or are they just soldered to jumper wires that go to the power leads from the batt. Awesome job
07-23-2011, 10:33 AM | #15 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Any updates on how this has held up under driving in terms of heat?
07-23-2011, 03:08 PM | #16 |
Works great! No issues. I comped with him last week, and he didnt have any issues.
07-24-2011, 04:44 PM | #17 |
heres my try at it. finally got the heat shrink in the mail yesterday 2 mamba micros 1 castle bec 1 futaba rx as seen in the pics its the same width as the brxl and just a touch taller and longer but not by much thanks for the idea |
07-24-2011, 08:41 PM | #18 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
i did the dual micros shrinked just like this, ran 2 comps this weekend, probably 10 minutes per run, no issues. (other than my driving)
07-28-2011, 08:48 PM | #19 |
I did someting similar on my rig. I pushed two mamba's together but found it easier to stick them with the capacitors on opposite ends to get the wires coming out the right way. I did not instlal the bec the same way as my bec is setup differently. I went to run it for a bit tonight and when I got done I put my finger down on my esc's and they were hot. Went to grab my heat gun and my esc's were at 130. I only ran for about 5 minutes but I am in Dallas where it is 198 degrees in the shade. |
07-28-2011, 09:21 PM | #20 | |
