07-21-2011, 06:54 AM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Safe time for charged Lipo?
What is a safe amount of time to have a Lipo battery charged or discharged, considering either is at the correct voltage?
07-21-2011, 12:18 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
I'm unsure exactly what your asking. Are you asking how long you can store a fully charged or discharged battery? Typically you wouldn't want to store a fully charged lipo for more than a few days, same for a discharged lipo, most chargers have a storage function that will charge or discharge the battery to a predetermined level for prolonged storage periods.
07-21-2011, 01:16 PM | #3 |
If you're asking how long it can charge before you really need to think about pulling it off, not sure, I've always let the charger handle it. I know the amperage does fall off at the end of charging, but I would still think if you're set up to charge a 3000 mAh battery at 3 amps (1C), it should still be about 60-75 minutes, give or take. I've always let the charger handle it and never had a problem. (Obligatory safety warning) Just take the normal precautions of using a charging sack, and have a fire extinguisher somewhere in the area. For time to discharge, this is why I like LVA's. I just plug mine into the balance port, and let 'er go, stop it when the LVA flashes. My discharge rig only draws somewhere around 10ish amps. I've never timed how long it takes to discharge my batteries, though. Sorry, can't help ya there. |
07-21-2011, 01:33 PM | #4 |
Sorry, perhaps I should have been more clear. Apparently the aluminum foil cap worked and you couldn't read my mind. Yes, my question is how long can one store a battery that is @ 4.2 Volts/cell and similarly @ 3.2 Volts/cell. My charger (Duratrax Onyx 235) doesn't have a storage option but I set a profile for about 40% Mah and it gets me close enough. |
07-21-2011, 02:43 PM | #5 |
Try not to let them set fully charged or discharged for more than a few days. They should be stored at roughly 50%.
07-21-2011, 03:34 PM | #6 |
Pebble Pounder Join Date: Feb 2010 Location: yankees suck
does anyone know exactly why this is? and there must be a limit to to how long one can store them at half charge? thanks, just curious Last edited by jaytet; 07-21-2011 at 03:36 PM. |
07-21-2011, 10:37 PM | #7 |
Not sure about the science behind why they should be stored at partial capacity. But I'm sure there are lipos in a Chinese warehouse somewhere, that haven't gone and won't be going anywhere for a long time .
07-22-2011, 09:28 AM | #8 |
Rock Stacker Join Date: Mar 2011 Location: Mpls
Also just FYI, storage temp matters somewhat too. I store my lipos at 40-50% and in the fridge. You can freeze them, but then you must properly thaw them. Don't charge a real cold batt. I heard of someone getting like 100 charges by always charging his lipo fresh out of the fridge. There is a lot of information, on this site and outside of it, on lipo battery use and storage. I think the people that fly with them work harder at getting every mah out of their batts....
07-22-2011, 05:31 PM | #9 | |
+1 If I know that my batts will not be used for a couple weeks or more, they go in a ziplock bag in the fridge. I've had batts in there for a year or more, and they still work great (after warming to room temp and charging). Cold temps slow down chemical reactions, so fewer bad things can happen. I wouldn't recommend freezing, and don't charge while cold. | |
