07-21-2011, 04:17 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| hitec hs-645mg not working. gets very warm
this servo looks new.. got it in a lot of rc i bought. plug it in. is seems like its jammed. case gets warm. took it apart nothing looks burn.. any ideas? trying to save it. from what i read hitec is a pretty good servo. thanks for the help
07-21-2011, 04:25 PM | #2 |
Rock Crawler Join Date: Jul 2009 Location: greeley
| Marbe the motor in the servo shorted out internally. I think the MG-645 fairly cheap. Might wanna think about tossin it or seein if Hitec might warantee it.
07-21-2011, 04:45 PM | #3 |
okk thanks
07-21-2011, 04:46 PM | #4 |
Just a shot in the dark but I once burned up a traxxas waterproof servo when I replaced a gear and put it together wrong and it couldn't center itself and it burned up the motor. Can you turn the output back and forth (with a horn installed obviously) by hand when it's unplugged? |
07-22-2011, 12:11 AM | #5 | |
If it dosen't move, open it up and check for broken gear teeth or "bits" of stuff floating inside the case. Also check the shaft holes in the case, they may be worn and allowing the gears to cock and jam. | |
07-23-2011, 06:19 AM | #6 |
thanks
