07-23-2011, 10:34 AM | #1 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Dx3e help
I pluged in the 645 servo into aux.and i get very very movement out of servo. I am running a bec on a mamba max.I am trying to get that servo to work for a winch.servo is fine. Thanks |
07-23-2011, 11:24 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
07-23-2011, 11:35 AM | #3 |
07-23-2011, 11:42 AM | #4 |
| Im thinkin he has it on LINEAR and its dialed way down for AUX-HI and LO
07-23-2011, 11:53 AM | #5 |
07-23-2011, 12:20 PM | #6 |
| I use mine on the 3P (3 position) but you have to adjust the HI LO dials on top of hte radio either way...and with linear...it goes faster as you hold the button down longer...it starts slow then speeds up when settings are that way...play with the AUX HI and AUX L dials on top in the linear position and see if you get what you want..if not try it in the 3P I would also look up HEYOK here on RCC and get one of his Servo controllers...they keep the servo from walking the line either way in or out..Look in the electronics section in the vendor threads... |
07-23-2011, 12:35 PM | #7 |
I have it going one way now how do i get it to go backward the same speed its really slow that way.
07-23-2011, 07:29 PM | #8 |
Adjust your end points on the 3rd channel.
07-23-2011, 10:54 PM | #9 |
07-24-2011, 06:54 AM | #10 |
| I like it when someone closes out a situation, then others (if they search) can see the issue, symptoms, suggestions and finally what resolved it. |
07-24-2011, 07:07 AM | #11 |
07-25-2011, 10:22 PM | #12 | |
servo was not completely gone so it was making the servo bid up.That search button didnt really help also. | |
07-25-2011, 11:51 PM | #13 | |
2-I work, a lot involves travel around the country. 3-Searches work only as well as your terms you look for. 4-Glad your servo issue is resolved and you closed this out. | |
