07-23-2011, 03:46 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: Elk River, MN
| Charging LiFe Battery
I have been thinking about picking up a few 2s LiFe batteries for bashing duty but am a little confused on charging times. I know my current LiPo batteries can only be charged at 1c that means that if I charge my totally discharged batteries at 1c they take about an hour. The LiFe batteries I am looking at say they can be charged at up to 15c. Sooo does that mean it would take 1/15th the time to charge them. (Assuming a charger capable of the given rate) The packs I am looking at are small 1050mAh ones and my charger has a max output of 5 amps. How long would it take to charge? |
07-23-2011, 07:02 PM | #2 | |
At 15C it would be ~4 minutes (wow), so 3 x that is ~12 minutes. | |
07-23-2011, 07:39 PM | #3 |
Newbie Join Date: Apr 2011 Location: norman
you have any links to those batts? Thanks |
07-23-2011, 08:00 PM | #4 |
I found a few on cheapbatterypacks.com for around $25 but they are kinda sketchy about specs, the others were from maxamps.com and were just a few bucks more.
07-23-2011, 10:10 PM | #5 |
1050mAh divided by 5000mAh times 60= 12.6 minutes That fast charge rate is one reason why I've really been wanting to get a couple and try 'em out. |
07-23-2011, 11:20 PM | #6 |
| Thats the reason I want to try a few too, figure if I can get them cheap enough I would never run out of battery since a 1350mAh battery lasts me close to 1/2 hour maybe a little more taking it easy even charging them at half what my charger can do will re-up them before I can use one up. That and supposedly there is no concern of fire with charging them.
07-24-2011, 12:30 AM | #7 |
Newbie Join Date: Apr 2011 Location: Victoria
Just remember that you'll probably need a slightly bigger pinion to get the same speeds cause the voltage is a bit lower, and with a bigger pinion you'll be drawing more amps so the run time will be less for the same mah battery.
07-24-2011, 02:30 AM | #8 | |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
For anyone interested the voltage per cell in a LiFe battery is 3.3v versus the 3.7v of a Lipo. Hobbyking has some decently priced LiFe batteries for anyone interested in trying them out. | |
07-24-2011, 06:49 AM | #9 |
I believe the LiFE batteries drop off in voltage fairly quick, then flatten out. This will likely seem like a LiPO with a low "C" rating. I see using LiFE batteries for radios, NOT motive power. I think Cheap Battery Packs had discharge curves for a number of battery chemistries. |
