07-27-2011, 01:02 PM | #1 |
Pebble Pounder Join Date: May 2010 Location: Ringgold GA USA
| Dual motor ESC's
I got a ? about dual motor setup. I have the Losi MSC12l esc out of a night crawler in my honcho . Iam gonna get the level3 RC dual motor plate and i would like to just use my esc and not have to buy a new one. I know the Holmes BR-XL can run 2 motors same with the FXR . I just want to know what makes a esc able to run to motors and if the one i have will handle it. Iam gonna wire it up like this and i will be running 550 size 55t motors. Last edited by Butcherinhd; 07-27-2011 at 01:15 PM. |
07-27-2011, 01:10 PM | #2 | |
Last i heard holmes has a sale going on, like 25% off or something on his br-xl's you might want to check into that. | |
07-27-2011, 01:14 PM | #3 |
oh yes i will be checking that out . But Iam quite fond of the esc because it has always worked never a problem ever . And yes iam running 55T there 550s
07-27-2011, 03:32 PM | #4 |
you will have no problem running 2 55t's on that esc. iirc its rated down to 12t, so it should be able to handle up to 2 27t's or 35t's on the safe side if you wanted
07-27-2011, 04:04 PM | #5 |
You should be OK, but now I have a question. Your rig, is it a dual motor setup running a single gearbox, or does each motor run on an axle?? If 1 motor/axle, you need to reverse the colors on the rear motor so it spins the other way. |
07-27-2011, 04:51 PM | #6 |
It will be 2 motors on a single gear box. Its the stock scx-10 gear box with Robinson Racing gears in it. I do need both motors to turn the same way. All the ratings i can find on the esc dont say anything about a motor limit . idk if it cooks i guss it cooks time to get this thing rollin just watin on the plate
