07-29-2011, 04:06 AM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: saipan cnmi
| Dx3e help
so I have my dig set up and dialed. Now the aux button doesn't work. I know the servo is fine cause when I plug the servo into the steering slot on the receiver the servo works fine... assistance please |
07-29-2011, 06:16 AM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
Check your third channel setting - it might be set to LIN, which would only bump the servo a tiny bit each time you hit the button. Also, make sure the end points are set correctly. For my VP dig, I ended up at about 3/4 of max(all the way to the right) for high and low. |
07-29-2011, 06:30 AM | #3 |
it doesnt seem to move at all. funny thing is it was working prior to...i bound my dx3s to and tried the 2 position and it worked flawlessly...ive only had the radio for about a month, hope i didnt get a lemon |
07-29-2011, 08:06 AM | #4 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Did you check the travel dials on top of the radio. If they are turned down you wont see any movement. Unhook you servo linkage and turn both up to 100% and see if it works then
