08-01-2011, 04:13 AM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
| GT3B recalibration?
Hi, Do I need to recalibrate GT3b with esc (cc sidewinder micro) after I flash GT3B to a latest firmware? Thanx! |
08-01-2011, 05:36 AM | #2 |
I believe so, if you are having throttle issues, recalibrate the ESC to the RX. The same goes for flashing new firmware to the ESC. |
08-01-2011, 07:09 AM | #3 |
Thank you Charlie.
08-01-2011, 10:47 AM | #4 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Have you gone through the radio calibration already? After the flash you need to recalibrate the radio for best results. After that then recalibrate the esc. Warning though if you are running more than 1 model off the radio with different recievers all the other vehicles need it also.
08-01-2011, 08:58 PM | #5 | |
thanx! Last edited by kc092755; 08-01-2011 at 09:01 PM. | |
08-01-2011, 09:13 PM | #6 |
| Not rebinding but recalibrating. Both the radio and esc can be calibrated. Calibrate the radio then calibrate the esc. I have a lot of things bound to mine and after I recalibrated the radio I had to recalibrate all the escs in my vehicles. If you are dealing with just one model nothing to worry about then |
08-01-2011, 10:22 PM | #7 | |
Thanx! | |
08-01-2011, 10:23 PM | #8 |
08-01-2011, 11:04 PM | #9 | |
GT3B Hack Question and Answer Thread | |
08-02-2011, 04:05 AM | #10 | |
How to measure the battery voltage? turn the volt meter to 20(2,20,200,1000), then place the red needle to + of the first battery and black needle to - of the last battery? Thanx! | |
08-02-2011, 06:17 AM | #11 |
08-02-2011, 08:36 AM | #12 |
08-02-2011, 01:29 PM | #13 | |
Then you should recalibrate the ESC's to each RX. If you only have 1 RX and 1 rig, it's easy. If you run more than 1 rig on the TX, make sure you have the correct model pulled up when you recalibrate the ESC's. | |
08-02-2011, 03:38 PM | #14 |
| As long as your pressed and held enter to exit out your calibration should be saved...best way to check is to make sure your battery voltage on the radio is the same as what your volt meter reads.
08-02-2011, 07:27 PM | #15 | ||
Are the number for each setting important? Mine are 72--448--843--108--688--984. Thanx! | ||
08-02-2011, 08:15 PM | #16 |
08-02-2011, 08:36 PM | #17 |
08-02-2011, 08:57 PM | #18 |
| yep that sounds bout right...thats the raw data the A/D encoders are reading. Then its converted to ppm, and eventually converted into pwm at the rx. But what calibration does is it sets those points to left. center, right positions on the pwm signal comin gout of your rx (1 ms, 1.5ms, and 2ms)
08-02-2011, 10:01 PM | #19 | |
08-03-2011, 07:24 AM | #20 |
How do you guys calibrate radio with duel esc's? one by one, or esc's and bec all solder together then calibrate both esc(red wires out) at the same time? Thanx! |
