08-05-2011, 04:47 PM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| 3s reading as 2s on charger?
I've got a fairly new 1.0Mah 3s battery that has only seen a few charges. I put it on the charger today and it reads as a 2s when the chager checks it. I took the wrapping appart and everything looks OK to me so I'm not sure if a cell is bad or what. Is thing toasted or is there a fix? |
08-05-2011, 04:56 PM | #2 | |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
08-05-2011, 05:03 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
Sounds like a dead cell to me. Do you have a volt meter? Or try a friends charger.
08-05-2011, 05:05 PM | #4 |
Rock Stacker Join Date: May 2011 Location: Fresno
I have had this happen a couple times. I charge it for about 30 secs on 2s to bring it up in voltage. Then go back to 3s and it works fine. I have a car that does not have a LVC so sometimes I run it a bit low getting back to me when the battery takes a dive. Been playing with Lipos for 5 years now with out an issue. Just be safe. MAKE SURE TO BALANCE CHARGE IT. Last edited by vette66_00; 08-05-2011 at 05:08 PM. |
08-05-2011, 07:35 PM | #5 | |
I'll give that a try, I "always" balance charge my packs, so what you would recommend?, quick charging or standard charging the pack for how long as a 2s before I jump it back to 3s???? Thanks for that bit of info. | |
08-05-2011, 07:46 PM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
i would use a multimeter to test the individual cells through the balance plug before and after you get it to charge and i would also test after a run, there is only so much a balance charger can balance if the pack is too out of whack, what charger do you have? if all 3 cells are close and the pack is just run down too far your probably gonna be able to recover it..but if one cell is way low..say less than 2 volts the cell is likley damaged..be carefull when charging Last edited by vonclod; 08-05-2011 at 07:54 PM. |
08-05-2011, 10:26 PM | #7 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
maybe one of the balance wire came loose?
08-05-2011, 10:32 PM | #8 |
| Just 2s charge it for 30 secs to a min. The pack will take it quick and bring the total voltage up. All you need is the minimum 3s voltage your charger will recognized. Then it should balance out the cells from there.
08-05-2011, 10:33 PM | #9 |
08-05-2011, 10:36 PM | #10 |
