08-05-2011, 05:20 PM | #1 |
Newbie Join Date: Jun 2011 Location: Gates
| Help please
Ok this is what I have, ae-2 esc, ar-3 rx and a cc bec on a axial wraith. I have used the search and cc web site. So I'm stupid. Here's what I need where does the 3 pin connector from the bec go? Ar-3 has bat, chn3, thrl, str. I did remove the red wire from the throttle. Does the 3 pin go to the battery or third channel.
08-05-2011, 05:29 PM | #2 | |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
08-05-2011, 05:48 PM | #3 |
08-05-2011, 05:54 PM | #4 |
Ok, so to run the lights then you plug the 3 pin that was in the bat to the 3rd channel on the rx. Cause if I plug the bec into the bat port I have to unplug the lights. Is that right, doesn't seem like I should have to use the 3rd channel to run lights.
08-06-2011, 12:33 AM | #5 |
| It doesnt matter, as long as both are plugged in then you are good to go. If you end up wanting to plug something else in the 3rd channel spot then just get a y harness and run the bec and lights to the batt port.
08-06-2011, 05:12 AM | #6 |
Thanks, if you can't tell this is my first RC.
