08-07-2011, 09:37 PM | #1 |
Newbie Join Date: Sep 2010 Location: usa
| what servo should i buy?
What is a good servo to buy for under $70? i need one strong enough to turn weighted 1.9 Mickey Thompsons fairly easy.
08-07-2011, 09:39 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: gervais
For $10 more you can get a spektrum for a lot of power
08-08-2011, 04:33 AM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
Hitec 7954SH, about $80. FTW. |
08-08-2011, 02:05 PM | #4 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Depends on what typef terain you intend to drive. Rough terain most 220oz.in/16Kg.cm(& up) servos would do. Trying to turn while going vertical with only one wheel over a edge but trying to turn try the 400oz.in/30kg.cm size servos. Savox SA-1283SG 416oz.in @6V $130.00 Savox SC-1232SG 305ox.in @6V $100.00 HD DS8325HV, 25Kg.cm @6V, 31Kg.cm @ 7.4V but could operate at 8.5V. Gives more choices than Hitec but as always it comes at a price. |
08-08-2011, 02:11 PM | #5 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
08-09-2011, 09:01 AM | #6 |
Pebble Pounder Join Date: May 2011 Location: san jose
Thanks for starting this thread. I'm building up an xr10 and need an awesome servo for a non-bankbreaking price. I'm shopping around most definitely. I might go with savox. I want a programmable servo. Just found out about those the other day,thanks to Crawford Tbolt meatclaws-talkatap |
08-09-2011, 09:03 AM | #7 | |
| Quote: Tbolt meatclaws-talkatap Last edited by inkdaddy66; 08-09-2011 at 09:06 AM. | |
08-09-2011, 10:46 AM | #8 |
What's the stall torque on a savox 1232sg? Tbolt meatclaws-talkatap |
08-09-2011, 03:35 PM | #9 |
Rock Stacker Join Date: Apr 2011 Location: Upper Peninsula, MI
| The Hobbico CS-170 is a rebadge of the Hitec 5955TG or 7955TG. Not sure which one, they have the same specs, just different control board. Probably the 7955TG for any newer CS-170, pretty sure the older ones were 5955TG. Either way, they are a solid servo. It has the same alloy heatsink case, plastic top piece.
08-09-2011, 04:01 PM | #10 |
Quarry Creeper Join Date: Oct 2008 Location: florida
I have also used the hobbico CS-170 and also the CS-150. I didn't know the 170 was a rebadged hitec but it worked well for me and had no problems with it. Definitly worth the price. The 150 is just under 200 oz-in and has a fair price also. But in this case more IS better.
08-09-2011, 04:17 PM | #11 |
Pebble Pounder Join Date: Jan 2008 Location: el paso
try a savox 0251 222oz @ 6.0 volt for $40.00 run this on my wraith with 2.2 tsl no problems. Jorge |
08-09-2011, 05:45 PM | #12 |
I have a couple Savox servos in my short course trucks and am very happy with them. They are very fast and precise. I'd certainly trust them. Both my crawlers run Hitec 7954SH and have plenty of steering power. Sure, it's $80 for a little piece of electronics, but it'd be comparable to a full hydralic setup on a 1:1 rig. You can run them straight off of a 2s lipo, potentially saving you the cost of a good BEC. I took one of mine apart and waterproofed it with dielectric grease and it is still going strong three months, and many hours of subersion, later. |
08-11-2011, 07:38 AM | #13 |
Rock Stacker Join Date: Aug 2011 Location: east,LA
Anyone have experience with ZNO-RC's servo? I got my new redcat in yesterday and already broke the front servo. This is the one im looking at buying. Mayhem High Torque metal servo http://www.zno-rc.com/store/index.ph...ct_detail&p=54 |
08-11-2011, 08:38 AM | #14 | |
Tbolt meatclaws-talkatap | |
08-11-2011, 12:09 PM | #15 |
Rock Stacker Join Date: Jul 2011 Location: Chesterfield, VA
| On subject question I cannot decide between two Savox Servos, Savox SC-1268MG "High Torque" Digital Steel Gear Servo (High Voltage)Torque: @6.0v - 208 oz-in. (13 kg-cm) / @7.4v - 361oz-in. (26 kg-cm) Speed: @6.0v - 0.13sec/60° / @7.4v - 0.11sec/60° Voltage Range: 4.5v-7.4v Weight: 62g Motor: Coreless Gear: Steel Case: Aluminum Heatsink Output Shaft: 25T Spline (Futaba) Dimensions (LxWxH): 40.3x20.2x37.2mmor or Savox SA-1283SG Standard Digital "Super Torque" Steel Gear Servo Dimensions: 40.8x20.2x37.4mm Weight: 80.0g Speed: @ 4.8V: .16 sec/60 @ 6.0V: .13 sec/60 Torque: @ 4.8V: 347.2oz-in @ 6.0V: 416.6oz-in Gear: Unique Steel Bearing: 2BB Case: Full Aluminum Output Shaft: 25 Tooth Spline Basically there is a $30 difference in the servos, one can run @7.4V, and one only @6V. I do cave a CC BEC Pro to handle the voltage. Just mot sure that the extra $$$ is worth it. Please help. Thanks in advance. |
08-11-2011, 02:14 PM | #16 | |
Rock Stacker Join Date: Dec 2010 Location: australia
Jethro, Australia. | |
08-11-2011, 02:23 PM | #17 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
08-12-2011, 04:18 PM | #18 |
Quarry Creeper Join Date: Dec 2008 Location: La Costa, CA
08-14-2011, 11:30 AM | #19 |
08-14-2011, 11:42 AM | #20 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
Savox Servos would fit your bill. the Savox 1256tg would be a great servo with 277oz torque at 6.0v. I use this in my 1/8 buggy and runs like a JR servo. does everything i want it to. points in the right direction, stays pointed even in hard turns, stays cool in temp and the torque is just there! |
