08-11-2011, 08:19 AM | #1 |
Newbie Join Date: Mar 2011 Location: philly
| BEC wiring and Glitches
Guys, I have added a CC BEC to my clod setup as diagramed below. I'm getting some glitches on both throttle and steering. I have read through some other posts, but have not seen a dual battery setup. Am I doing this right? Is there a better way? ClodWireing by prioret, on Flickr |
08-11-2011, 12:48 PM | #2 |
I guess the only questions I'd have would be... 2.4 radio? What ESC? Which BEC? Did you program the BEC to output the proper voltage? Did you take a voltage reading at your BEC's connection point and make sure it's not getting the voltage doubled? And/or can your BEC handle the input if the batts are for some reason hooked in series? Check out the lower left image at -this page- (all the way at the bottom, left side) you may need to look at maybe transferring your connection point to the other battery's leads. |
08-11-2011, 05:15 PM | #3 |
I would say that if your are not using a 2.4 radio that you are having interference issues. Try getting the receiver as far away from the BEC and ESC as possible, that should help but you really should upgrade to 2.4 if you dont already have it. |
08-11-2011, 08:47 PM | #4 | |
Its not 2.4 its a futaba 3pm The esc is a Traxxas EVX2 The BEC is the CC BEC. I dont have a programmer so the BEC is putting out the default voltage, which is I believe 6V The BEC is only getting voltage from one battery pack. even if it got both, it would be under 25V so I would be safe. Before I had the BEC I didn't have any glitches, I have tried the BEC in multiple locations and it hasn't helped. I have it wired the same way as the diagram you pointed out. The glitches occur both at speed and stationary, and get worse if the radio gets with in a couple of feet of the truck. Because of this I don't believe its due to a voltage drop to the RX. I was thinking of changing it so that the RX is powered by the ESC, and I could power the servos with the BEC. Quote:
08-11-2011, 08:53 PM | #5 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
i believe the default BEC voltage is 4.8v not 6v. BTW did you take out the red wire from the ESC side? i accidently left mine in, and it caused very bad glitching. How does your car glitch? does it shut off momentarily then come back on? |
08-11-2011, 08:53 PM | #6 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
08-12-2011, 04:23 PM | #7 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Test ferite rings on the power wires at the BEC and ESC's Some BEC's comes standard with it. I've got a simmilar setup and problem. Everything works fine until I plug in the steering servo signal wire. The RX then looses it's bind but without the bec or esc and RX on battery nothing happens. Lets say it's some resonance in the wires. Had less problems with same setup on 27MHz. |
08-13-2011, 11:18 AM | #8 | ||
Okay, (I apologize for the tread hijack, sorry), I have a question on how you'd wire that up. Red & black from BEC to servo (or brown and orange, whichever), and white (yellow) (signal) to the reciver, got that much...... Does the black (or brown whichever) also need to go to the reciver to complete the signal circuit? (assumes all three wires from ESC are connected to the receiver) | ||
08-13-2011, 08:54 PM | #9 | |
Its definitely the best way to wire a BEC for a crawler. | |
08-13-2011, 09:47 PM | #10 |
Okay, thank you.
08-14-2011, 08:07 AM | #11 | |
I just run the BEC red & black direct to the servo. | |
08-14-2011, 01:04 PM | #12 |
Pebble Pounder Join Date: May 2011 Location: Spring
I had same glitching issues with my setup. My CC BEC has 2 outputs. Each were hooked to a servo via a y-harness. I had only the signal wire going to the RX. After having issues I was told to try to also include the ground wire to the RX. This took care of my problems. Radio sys I use is Airtronics m11 FM. I myself didnt have any issues until I hooked up the BEC. But try ground wire to the RX. My BEC is mounted on top of battery tray. ESC and RX mounted behind battery tray. Servo rear motor wires run right by RX and I do not have any glitching issues. And I can drive it 100+ feet away and still have full control with no problems. I too thought with the extra electronics I had more radio static and interference with added BEC and myself tried to move components around to get the cleanest signal. Last edited by Rok Krawl; 08-14-2011 at 01:06 PM. |
08-14-2011, 01:27 PM | #13 |
| That is very strange. I havent had any issues with my setup using the y harness. Maybe those Airtronics RXs are more sensitive to interference than what I am using...
08-14-2011, 04:01 PM | #14 | |
Seems like Futaba doesn't care, others are picky. It's not a good/bad thing, just how they work. | |
08-14-2011, 11:56 PM | #15 | |
If that were the case then the servos would be at a different ground thne the rx, so you could have a bias on the signal wire and possible clip some of the pulses. | |
09-12-2011, 05:47 PM | #16 |
09-13-2011, 06:32 AM | #17 |
