$10 RX for DSM2?? Got this email from HobbyKing...I think a lot of yall probably did as well. http://www.hobbyking.com/hobbyking/s...Receiver_.html I have no idea what channels do what on an aircraft RX...but would it be possible to use this on a scaler rig? The compact size should be very easy to fit inside any waterproof box! Says it binds with any Spektrum DSM2 TX. |
I don't see why it wouldn't. Heck, it's only $10 buy it and try it. "thumbsup" |
The only problem I can see is that it is an aircraft receiver and may have different protocols than a surface receiver which could be incompatible with a ground transmitter. Remember that Spektrum makes aircraft DSM2 radios as well as surface radios which do not play well together. But at $10 + s&h it may be worth a try. So please let us know if it does work with a surface radio. |
Key features. Super light weight 2.5g / 2.9 grams with shrink tube! Compatible with DSM2 1024/2048 aircraft radio and module systems 4 Channels Compact design 36x14x7mm , with shrink tube 37x15x8mm Short 29mm antenna for mounting in almost any location. |
I ordered one. Ill post how it performs when I get it. Tbolt meatclaws-talkatap |
