08-18-2011, 07:00 PM | #1 |
Quarry Creeper Join Date: Jul 2011 Location: Monterey, CA
| 7950TH Noise Clicking without load/at neutral
Picked this up used off a forum member here, I noticed it was making some clicking noises. A few of the guys I crawl with have the same servo, no clicking, kinda strange. Uploaded some video, apparently this little pinion gear coming off the motor is twitching pretty badly. If I put my thumb on various places of the circuit board it'll stop making noise & become quiet. Second video should be up shortly it's stil processing, just shows the pinion gear twitching in low quality... |
08-18-2011, 07:04 PM | #2 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
oh that clicking noise, i thought you meant something worse. that is normal, i believe the circut board makes that sound tracking where the "coreless" motor is positioned at, in order to determine how much more turns it should do to be as accurate as your steering wheel. also, this allows it to be centered a lot better compared to analog, because analog checks the rotor like less than 100 times per sec, where digital checks the rotor like 500 times a second, i forget. |
08-18-2011, 07:06 PM | #3 | |
08-18-2011, 07:08 PM | #4 |
dont worry, after looking at that, i may be a dumb@$$... BTW, is the Servo really loud? i could barely hear you in that vid.. im starting to think that your servo may have a bad servo amplifier i beleive it is.. |
08-18-2011, 07:09 PM | #5 |
| turn the audio up on the vid, it's pretty loud, in a quiet room I can hear it from more than a few feet away.
08-18-2011, 07:12 PM | #6 | |
About that little gear twitching, it could just be the servo checking where the rotor is placed at, to make sure its centered. | |
08-18-2011, 07:15 PM | #7 |
Rock Crawler Join Date: Oct 2010 Location: triad
totally normal
08-18-2011, 08:06 PM | #8 |
| x2 That's the servo trying to make sure it's centered. If you'll mount it on your rig and turn it on...you'll notice that if you push the tires a little off center itll make that noise...and if you fiddle with them enough you can get it centered and it will stop making noise.
