08-21-2011, 12:51 AM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: united kingdom
| is my battery dead
as in title i recently let a mate borrow my batteries and did not realise he did not have a lipo cut off esc. now when i charge the battery he used it will not peak 1 sell is reading 3.705 while cell 2 is reading 4.212 does this mean that cell one is damaged and would i be able to recover it this will at least one thing remind me not to lend out my batteries thanks |
08-21-2011, 01:23 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Well they are above 3.0v per cell so that is good news. I would balance charge them to see if you can get them to match a little better in voltage.
08-21-2011, 01:30 AM | #3 |
i have tried that and it wont peak and was on charge for a lifetime cheers |
08-21-2011, 03:06 AM | #4 |
Pebble Pounder Join Date: Jul 2008 Location: Tamworth, England.
Ian, try and run the battery in something for a little while then try and do a balance charge on it. If that doesnt work it looks like it might be bin fodder.
08-21-2011, 05:43 AM | #5 |
Best thing to do is to use an equalizer which will discharge the higher volt cells to match the lower one. Then balance charging it and be patient. If it doesn't equalize after a few cycles the battery is toast.
08-21-2011, 10:00 AM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Another alternative you could try is to charge the bad cell through the balance port at a low current setting until it reaches full capacity then run the pack as normal and try to balance charge again. Dont run the pack to LVC, do a run of 25 - 50% of your normal run. Play it safe. |
08-21-2011, 01:20 PM | #7 |
thanks for the replies again but where can i get an equalizer there does not seem to be any available i the uk and how can i charge through the balance port as i have never done that before thanks again |
