08-23-2011, 06:31 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Osaka, Japan
| Broken motor tab: Repairable? - SOLVED!
Working on my Losi MRC and somehow I managed to break the tab off the motor: The solder joint held, but the tab itself is broken off flush with the plastic end cap, and I don't thing I can get the soldering iron in the gap. Suggestions? New motor time? Thanks -val Last edited by LAV25; 08-23-2011 at 07:45 PM. |
08-23-2011, 06:53 PM | #2 |
deffinatly need a new motor,you dont k ow what your missing
08-23-2011, 07:08 PM | #3 |
If it was me, I would shove a copper wire strand (maybe ~0.030" dia) between the plastic and the remaining tab. Then, heat it up and flow in some solder. Attach the ESC wire to the extended wire end. |
08-23-2011, 07:24 PM | #4 |
Pebble Pounder Join Date: Jun 2011 Location: Salina
08-23-2011, 07:45 PM | #5 | |
And solved! Thank you very much! -val | |
08-23-2011, 08:09 PM | #6 |
