Help charging batteries I know it sounds stupid, but I am kinda lost. I don't understand charging times for certain batteries. I have looked and yes I did check the battery university, but all it did was make me even more confused. Here's what I have. I have 2400 MAH battery packs and a Hobbico AC/DC auto-charger. Hobbico says that it is rated at a 1 amp trickle charge. It's cover says 35 to 75mA. Please correct me if I am wrong. I want to trickle my packs. If I understand the university thread correct, for a 2400MAH pack, I trickle charge them for 24 hours? Is this correct? God I miss my old charger! Plug in and it told you when they were charged. I also have several 3300 Nimh packs I got in a trade. Will the Hobbico charger charge them( asking cause I have seen nothing that says otherwise)? Would it charge for 33 hours? I know these are very dumb questions. But I really truly thank whoever sets me straight on this. |
i was in your same situation a few weeks ago..... and ya, the battery university gave me more questions than answers. but, from what i have read from many sources, nimh batteries dont like to be trickle charged; especially for days (nicad batteries can be trickle charged). so i ended up buying a digital peak charger and a 3300nimh battery. i followed the directions on the charger and it charges for about 80 minutes and gives me 3 hours of run time. be sure that your charger can charge nimh batteries or else it will destroy them. i also recommend this charger from tower hobbies: http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXCLD5 |
The only problem with that charger is that if you use AC you have a max charge of 3.0 amps. If you go DC, then can go up to 5.0. Found that out after I bought it. I still use it, just hook it up to the 1:1 for the bigger packs (I charge 3300 at 4.5 and 3800 at 5.0). |
Charge time is as simple as filling a 5 gallon bucket at a rate of 1 gallon per minute or driving 55 miles at 55 mph, right? a 2400 battery at a rate of 2400 ma will take an hr At a rate of 1200 it will take 2 hrs. |
Yes, I should have said "within limits" and for this purpose of explaining charge times I did not throw any over charge into the mix because it is pretty meaningless unless chargeing at slow rates. Water leaking from a 5 gallon bucket at a rate of a drip per minute. right?;-) during the fill up. Hopefully hvydty1 sees how to figure the times now . To trickle charge the packs use this 150 % or overcharge at a c/10 rate. 240 ma chargeing for 15 hrs for a 2400 delivery. |
