08-24-2011, 08:26 AM | #1 |
Newbie Join Date: Oct 2006 Location: uk, wakefield
| hobbyking 6 ch mod
ive had a DIG system set up on ax10 for sometime but never had it set up properly, a basically had to dial the position in manually every time i wanted to use it, a real pita to be honest! what im thinking to do is take the right hand dial out and put a 3 position switch in place. would this be as simple as that ? |
08-24-2011, 10:24 AM | #2 |
is the radio a ct6b that needs a computer to change most the settings? if so i have one that i put a 3pos switch in. to do it i left the dial/potentiometer inside the radio and soldered the 3pos switch to the 3 wires going to the dial, just need to be sure the dial is centered and it worked great till i went to a hacked gt3b
08-24-2011, 03:41 PM | #3 |
Yep, just take the wires from an unsued pot and hookem up to a switch setup like this, keep the center wire in the center and the outer wires to the outside Also if you have a CT6B i highly recommend this software http://www.sgr.info/usbradio/default.htm |
08-25-2011, 02:07 PM | #4 |
yh i do have a CT6B radio. Losikid thanks for the picture and the link, ill check that softwere out thanks |
