08-27-2011, 04:14 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Project box and LED controller ?s
I am thinking about moving all of the electronics to project boxes on the sliders on my Honcho. One housing the ESC (AE-2) and the other with the rx (2.4 Axial) and LED controller. First question is what to do with antenna? Looking at some pics I haven't figured out what is best, some look like the whole antenna is in the box. What would that do to the performance? Also, does anyone know if the Dingo LED controller is any different than the Honcho RTR controller? The Dingo has 4 white LEDs and Honcho only has 2. I'm wondering if I can plug one of the Axial 5 light strings into the Honcho LED controller..? The rearranging of stuff brings up the thought that I may want to shorten some wires just to clean them up some. Any reason I shouldn't do this? I have a lot of extra battery to ESC wire floating around. Thanks, Kevin |
08-27-2011, 04:26 PM | #2 |
Quarry Creeper Join Date: May 2011 Location: Ak
I coiled the antenna in the box around the parameter and haven't suffered any glitching or range issues.
08-27-2011, 04:33 PM | #3 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
The only wire you can't shorten is the antenna. If you are always close to your rig you could probably leave it in the box as long as you place it away from the other wires. Mine is laying down along the frame. All brushed motor wires can be changed. Some brushless motors have wires that come right off the windings and must not be messed with. It is usually obvious (remove the dust cap if needed) whether the wires are soldered to the motor or if they come from inside it. |
08-27-2011, 05:29 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
the dingo and honcho controller are the same and yes u can plug in that light strand.
08-28-2011, 12:10 AM | #5 |
Thanks for the replies, looks like some of my plans might work out for a change...
08-31-2011, 06:19 PM | #6 |
| That's how I did it. |
08-31-2011, 07:08 PM | #7 |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
how ironic. I literally JUST did the same thing with my SCX10 not 100% done (need to mount the boxes and tidy up the wires), but everything works personally, I'm just going to coil the antenna wire inside the box and see how it works out |
09-01-2011, 09:07 AM | #8 |
Quarry Creeper Join Date: Oct 2010 Location: Grandview, IA
As far as the RX antenna, the antenna on my Spektrum Rx was never long enough to get out of the electronics box on my Slash, So i just ran the wire along the bottom of the box and still had 100 yards of range. With a crawler you're always close to you could really do whatever you wanted short cut it off and be okay Also nice build there, really like the way you put terminals in the project boxes. Much cleaner looking then holes with silicone clogging them. |
09-01-2011, 09:21 AM | #9 |
Did you solder those ring connectors on rather than crimp them? Crimping causes resistance and is very inefficient. Very nice setup. I use those project boxes on my rigs and they work great. You should be fine leaving the antennae wire in the box, I do it on my Spektrum. You might lose signal if the box goes completely underwater though. |
09-01-2011, 09:47 AM | #10 | |
09-01-2011, 11:02 AM | #11 | |
tinned the wire, put it in the connector, crimped it, then hit it with the soldering iron again to liquify the solder and make it bond with the connector Sent from my space age wireless communication device. | |
