09-01-2011, 07:20 AM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: united kingdom
| tekin rs brushless combo
i am running a tekin rs with a 13.5 combo in my wraith. the thing i am having problems with is that its faster in reverse than forward. what do i need to do to reverse this i have looked at the instructions and they dont really help do i need to just change the wires configoration or is it do-able from my laptop at the moment i have a-a b-b c-c i hope this explains the issue cheers |
09-01-2011, 08:30 AM | #2 |
Have you tried reversing your throttle channel or reversing the motor direction on the ESC?
09-01-2011, 08:46 AM | #3 |
Quarry Creeper Join Date: May 2011 Location: Ak
Hook it upto hotwire and reverse your motor. If you are running sensored you can't swap wires to put the motor 180 out of phase to reverse it. If you can't hotwire it you need to flip your diffs which will fix your problem.
09-01-2011, 09:23 AM | #4 |
used my rear wraith axles for ease of access. Remove tires, hexes, drive pins. Pull setscrews and lockouts Remove diff cover Pull bearing caps Remove diff Replace diff |
09-01-2011, 09:24 AM | #5 |
This will reverse the rotation of your axles
09-01-2011, 09:35 AM | #6 |
09-01-2011, 09:38 AM | #7 |
ok thanks for the help i reversed motor through esc and didnt seem to do much so reversing the diffs may be next. i am also having problems with the brakes they either slam on or roll i cant seem to get them to stop without cocking a wheel anyone using this setup as all the links seem to be for racing only thanks again |
09-01-2011, 10:10 AM | #8 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Look at the RS and pull a little bit of throttle. Which side do the LEDs start lighting up from? MODE button side or INCR side? It sounds like it hasn't been calibrated properly.
09-01-2011, 11:03 AM | #9 |
i have done that and it lights up from the incr side for forward and mode side for reverse i have re-calibrated it and the only way i can get it to set is by pushing my throttle to what i would use as brake/reverse away from me as if i hold the throttle in position i.e trigger towards myself it wont bind cheers |
09-01-2011, 11:28 AM | #10 |
I have the rs/ redline 17.5t sensored combo. The dragbreak setting is definitely setup for racing with much higher geared machines. I ended up turning mine off yet still end up on my lid if I don't ease off the gas.
09-01-2011, 11:29 AM | #11 |
Check your throttle deadband. Set too low and your esc won't arm.
09-01-2011, 02:30 PM | #12 | |
09-01-2011, 02:45 PM | #13 |
Ah right I will try that as I am using a futaba 4pl so that could explain things Thanks for all the help from everyone Cheers ian |
09-01-2011, 03:50 PM | #14 |
Yep, definitely have to reverse the 4pl. Let us know once you try that, I'm 99% sure it will work!
09-02-2011, 12:44 AM | #15 |
will try it after the weekend as i am away and let you know how i get thanks again |
09-02-2011, 01:40 AM | #16 |
right just tried it again it pairs fine but puts my trigger the wrong way round so it looks like flipping the diffs round is my answer. thankas again |
09-02-2011, 09:07 AM | #17 |
Or if you have a HotWire you can reverse the direction and keep it sensored. But flipping the diffs looks pretty easy on this rig! I don't have one yet |
09-02-2011, 10:30 AM | #18 |
If you want a basher or trail rig it is awesome. In tight spaces she takes on a " Bertha " attitude. Needs to be modded a bit to make it crawl worthy. Just my .02
09-04-2011, 01:04 PM | #19 |
i would like to say a big thank you to sc convert as i have just flipped my diffs and the problem is solved. thanks everyone for there help cheers ian |
09-05-2011, 01:37 AM | #20 |
Glad to help. I had the same problem with the same setup. It turned out an easier fix than I thought it would be. If only axial would build axles like those for the ax/scx10.
