09-02-2011, 12:54 PM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
| Banana Plugs
Quick question, just got my Lipo's today and they use banana plugs. Are these absolute garbage, or can I use them safely? If I need to switch to another plug, how do I go about it without cutting the wires, if thats possible? Also, the Thunder AC6 did not include a Deans charging connection. Where can I find one if I switch over to deans plugs? |
09-02-2011, 03:12 PM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
I would go with Deans plugs. Easier to deal with. Check the links below http://www.cheapbatterypacks.com/Cus...er.aspx?mid=22 http://www.cheapbatterypacks.com/Pro...ans-Plugs.aspx |
09-02-2011, 04:43 PM | #3 |
Can I remove the banana plugs from the lipo without cutting the wire? Id like to keep the wires as long as possible.
09-02-2011, 04:58 PM | #4 |
Banana plugs, like from the home speaker world?
09-02-2011, 05:15 PM | #5 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
He must mean bullets. Just cut them as close as you can. At most you will lose an 1/8" which isn't going to affect anything.
09-02-2011, 05:29 PM | #6 |
add deans that way you do not accidently reverse the polarity. you can probaly even unsolder the plugs and resolder the wire to a deans plug losing zero length. |
09-02-2011, 05:38 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
AC6 doesn't come with deans. Cut one of the other adapters and solder on the deans. I cut the tamiya adapter.
09-02-2011, 06:02 PM | #8 |
At first I thought you were referring to the tubes in the battery but I'm sure that you mean the bullet connectors on the battery like from Hobbyking. I actually like them on my 5S packs they are 5mm and in housings that prevent incorrect plug polarity. I just made a bullet to deans adapter to use with my charger. You can cut the bullets off the battery and replace them with a connector of your choice. |
09-02-2011, 08:34 PM | #9 |
I guess they are just bullets then. Im more familiar with the bullet types on motors, these were different looking to me. Batteries should receive the female deans plug correct? |
09-02-2011, 10:11 PM | #10 |
09-04-2011, 09:46 AM | #11 |
should I use the bullets that came with the ESC to connect to the motor or go with deans on that as well?
09-04-2011, 10:44 AM | #12 | |
If this is what you have, I would change them to Deans or some other better connection. Put the "female end" on the ESC so they are different from the battery connection & you don't mix them up! | |
