09-02-2011, 09:40 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| LED voltage help.
Need a little help with the maximum voltage that a 5mm led can take. I am under the impression that all of the 5mm led lights are 12 volt. Please correct me if i'm wrong. The reason i'm asking, i want to run my led's off a 3 cell lipo. I have 5 led's on a light bar as of now, i want to add more in the near future. Also, what is the average rating of the resistor that is used in the light kits. I just don't want to burn up the led's. Thanks for you're help. |
09-02-2011, 09:48 PM | #2 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
I could be completely out on this one but the red LED I just put on my power supply called for a 330 ohm resistor for 12V. I'm sure if you search there should be a chart or some sort.
09-02-2011, 10:36 PM | #3 | |
Plug those numbers into a led calculator (google it) and it will tell you what resistors you need and if you can wire them in series to eliminate the resistors. | |
09-03-2011, 02:22 AM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
umm, try this.... there are so many LED CALCULATORS out there I cant recomend any one over the other anymore http://www.google.com/#hl=en&sugexp=...w=1486&bih=689 . Last edited by cogfounder; 09-03-2011 at 02:26 AM. |
09-03-2011, 07:10 AM | #5 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
first you need to decide if you want to run them in series or parallel. MOST, not all, white/blue led's are rated 3.6v, and rated at 20-25mah. if you run 4 in series, you will not need a resistor. If you are running 3, then you'll need to get the correct led to drop to 9v into the led. http://ledz.com/?p=zz.led.resistor.calculator I'm no expert, but I have been toying with them for a long time. If you run 5, I'd suggest running them parallel, and just use the calculator that I linked to to figure out the resistor you need. |
09-03-2011, 07:34 AM | #6 |
Great, thanks for the info. I guess i got to vague with the question. These are 12 led light set i got on Ebay, there are all wired up with the resistor. I cut the solder point of so i could untangle the individual Led. I only used 5 out of the set for now. Can i plug the set of 5 led's to a 3 cell lipo? All led's wire in parallel. If i do, will the voltage be to much for the led to handle? Thanks. Last edited by stelerzman; 09-03-2011 at 07:37 AM. |
09-03-2011, 10:10 AM | #7 | |
09-03-2011, 11:49 AM | #8 |
Ok, but all of the led's have there own resistor, so 5 led's with 5 resistors. Am i in the same situation, to muck voltage?
09-03-2011, 12:44 PM | #9 | |
If there was a resistor for the whole group, then you DO have an issue. Based on what you are stating, I believe you are good to go. | |
09-03-2011, 02:37 PM | #10 |
Ok, great. Thanks, I'll give it a try with a 3 cell lipo and let you know what happens.
09-05-2011, 09:48 PM | #11 |
For everyone's info, if you have purchased an led light kit with the resistors included and want to connect them to a 3 cell lipo you're in luck. The info i gathered is useful. I tried the info that was given to me by members of RCC. All the info is useful, and yes you can connect a installed resistor LED light kit to a 3 cell lipo as long as you are installing a 5 LED light set or more and as long as they are wired in parallel. This is just an example, I had them plugged in for at least 5 minutes, all the Led's stayed on the whole time. I see no problems with this setup. Thanks to all that posted and helped with the solution to the question. |
09-06-2011, 05:20 AM | #12 | |
09-06-2011, 04:18 PM | #13 |
No problem. I also hate when people ask for help then get the help and let people hanging. Again, thanks for the help.. |
