09-06-2011, 09:42 AM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: vienna
| help: mongoose esc motor combo error lights
i did a search through the forum and found some info but nothing in detail I have a mongoos esc motor combo install it and got the solid red, amber/yellow and blue light nothing in the mnaual or website regarding the solid 3 lights I even swap out the motor with another exactly the same novak motor and still the same even reinsert the sensor wire again and no luck switch batter too and no luck using the losi 7.av 600mah 2s2p lipo reciever is futaba RF614FF help thanks |
09-06-2011, 01:05 PM | #2 |
I didn't find much beyond this.... http://www.teamnovak.com/tech_info/ts/ts_oneTouch.htm Did you try to calibrate the ESC to the RX? --You usually need to have the throttle EPA's set to 100% and the throttle trims to "0". Is the black or brown wire (from the ESC to the RX) towards the outside edge of the RX when plugged in? |
